Results 1 to 10 of 14
Thread: fitting a Tiger2 winch
    Patrol Guru The BigFella's Avatar
    We are located in the Port Stephens region of NSW, sand, water and fun in the sun!
    I just picked up a good 2nd hand Tiger2, has any body fitted one into a genuine steel Nissan bar. Any info greatly appreciated.
    The BigFella
    500,000ks and still counting!
    Yep strip it. gear box and motor and make sure it is all good mate. I just recently got an X9 Superwinch off a 200 series that had not done a pull but had been on the car for 5 years and OMG!!!! It was Brand New outside and FARKKKKKED inside!
    Strip it.
    Check also that you might have to rotate the motor on the drum to get it to line up right? maybe the free spool end?
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    The BigFella (16th November 2012)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Strip it.
    Of course it was FARKKKKKED Darren, It was mounted to a Toyota, it crapped itself in hope the owner would take it of and buy a new one
    Expert Bloggsy's Avatar
    Perth WA
    Fitted a 12,000lb Tigerz11 into my GUIII genuine steel bar about 2-3 years ago. They need to be mounted upside down so the gearbox is on the driver's side. The gearbox will need to be removed and rotated (if not done already) so that you can access the lever from the front of the bar to engage/dis-engage. Not sure if you'll need longer bolts too, mine did, I think only about 5-10mm longer. Only other thing I did was flip the power cable around so that the power isolator is under the bonnet and not in some ridiculous place behind the bar where you can't reach it and others can tamper with it.
    Hope that helps a bit.
    Cheers,
    Darren
  6. The Following User Says Thank You to Bloggsy For This Useful Post:
    The BigFella (17th November 2012)
    tried fitting this winch today and its too bloody big,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,, misses out by about 40mm in width?
    dont really want to have to fabricate a cradle, may as well just sell the bloody thing and start again?
    frustrating thing is everyone said it would fit no dramas?
    ah well, thats life I suppose,,,,,,,,,,,,,,,,,,,,,,,
    The BigFella
    has anybody else had problems fitting these winch's?
    I only have 200mm from the bolt holes to the chassis rails each side.
    Now on the gearbox side of the winch this isn't a problem, however on the motor side of the winch it misses out by 40mm?
    The BigFella
    What size Tigerz is it? Yes there is 1 model that is much bigger and you will have trouble with and i think that you may have it. The only model that is longer is the 2 speed 'Comp' winch, bit of a con as the hi-speed only works on "No Load" so good for spooling in and out but no good for recoveries.
    All the single speed Tigerz are a similar length and made to fit a Nissan bar without trouble.
    Sell it and buy an Aldi winch or Super Cheap auto winch mate you will be much happier
    Have you got a pic of the winch mate?
  10. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Adventurous (22nd October 2013), The BigFella (19th November 2012)
  11. #8
    Hardcore healy's Avatar
    south east melbourne victoria
    Mate jump on ebay look up TREX winch 13000 pound $360 delivered I've done about 8hrs on it 2hours at a time and i couldn't be happier with it
  12. The Following User Says Thank You to healy For This Useful Post:
  13. #9
    You've nailed in one, its the two speed comp winch! Lucky me aye!
    This mother is going on my car trailer, Ill buy myself another one that fits this time!
    Thanks for the feedback guys, awesome!
    The BigFella
  14. #10
    If its only 40mm could you notch out and cap a bigger hole in the rail??
    Owner of
    Westy's Accessories
