Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Lift kits
    Beginner whitestickle's Avatar
    Burnie Tasmania
    Lift kits
    With so many brands and types of lift kits what is the best to go and how high. Is there any law with how high you can go.
    Thanks Whitestickle
    2" lift is the legal maximum on a Patrol.
    Old Man Emu (ARB) and TJM have good quality kits. Kings springs and Koni shocks are also a top combination. There are heaps of other quality suspension manufactures out there but they are probably the most most common.
    Tony
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Laws vary from state to state, but general consensus is 50mm will gain the least amount of attention. Qld as an example has no specified limit, stating in preference of a height measurement, that any modification to the suspension setup must be installed by a licensed installer, and be of "sound engineering practices". It is a dead set gauntlet of what is acceptable out there these days and what isn't, but start with your state roads authority for any publications/legislation/amendments particular to vehicle modification ...
    As per Tony - heaps of options out there, but the brands mentioned are well recognised and generally well trusted ....
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by Bigrig View Post
    what i'm moving 2 queensland!!!!! anyone know what the rules would be if i bought a raised vehicle from QLD then re registered it in NSW, would it have 2 go over the pits???
  5. #5
    Oct 2010
    Quote Originally Posted by toddrhind View Post
    More than likely I'd suggest ...
  6. #6
    Aug 2010
    17 Post(s)
    dam was hopping to find a loophole, but then again its prolly just as dear 2 get a licensed installer 2 install the mods like in QLD then to just do it myself and get it engineered like in NSW
  7. #7
    Burnie Tasmania
    can i also use 2in body chocks aswell
  8. #8
    Body lifts need to be engineer approved.
    Tony
  9. #9
    perth.kelmscott.
    body blocks are illegal in wa but check your own state regs about it i think there illegal throught aus
    tony beat me too it by seconds
  10. #10
    Aug 2010
    17 Post(s)
    Quote Originally Posted by whitestickle View Post
    not with a 50mm suspension lift
    you can have 50mm on body or 50mm on suspension... not both, depending on the laws in Tasmania, but that's how it is in NSW
