Page 33 of 33 FirstFirst ... 313233
Results 321 to 327 of 327
Thread: Big_Fletcha's GU III
  1. #321
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Quote Originally Posted by Lowy44 View Post
    Where'd ya get the led's from for the bullbar lights Fletch?
    Got the LED bullbar lights through my work, however can get them from Autobarn or Bursons.. They are made by a company called LED Autolamps and the part number is 175AW
    Fletcha
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  2. #322
    Oct 2010
    Tatura VIC
    Well instead of buying a catch can being i like to build things i decided to make one haha.. Its made from PVC pipe with caps both ends and filled with Stainless metal Scourer's.. Copied the design from a another member of an un-named forum and aparently works well.. Time will see
    All up cost me about $50 and ill get 2 out of it as i will make another for my housemate TUR7LE
    Few Pics
    The Can
    All Plumbed up
    You can see the clear drain tube coming out the bottom
    The Drain Tube with a tap on the End, will eventually be plumbed back into the sump
    Pic of my Glowing bonnet scoop when its actually dark haha
    Apprentice Sparky
  3. #323
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    This will be a good exercise to compare between your home made and my provent
    but why would you want to put dirty oil back in the motor ? Ive had the provent for a while now
    and ive noticed the oil level dosnt drop in the motor but the mix of diesel and oil fumes that come from the rocker
    cover turn to a black oil which in turn will contaminate your nice new clean oil and you,l need to change
    earlier than you thought
  4. #324
    Awesome GU mate!
    88 GQ patrol 4.2l Carby 2" suspension, 2" body
  5. The Following User Says Thank You to TJH For This Useful Post:
    big_fletch (9th November 2012)
  6. #325
    Oct 2010
    Tatura VIC
    Quote Originally Posted by roofy View Post
    Yer thats a good point Roofy, ill see how it goes after a couple of thousand k's and decide then.. Might just leave it as it is for now.
    Next ill be pulling the butterfly out of the Swirl valve and hopefully should help a little in the lower revs.. Then my intercooler as its leaking pretty bad now.. Time for a ASE upgrade lol
    Apprentice Sparky
  7. The Following User Says Thank You to big_fletch For This Useful Post:
    Sir Roofy (10th November 2012)
  8. #326
    Looking great mate
  9. #327
    Advanced Lowy44's Avatar
    Hey Fletch, tough looking wagon mate. Can you post up a pic of how you ran power to your roof rack lights? Ive just got my rack and am looking at how to do the same....
