View Poll Results: Are you coming and want to join in the big cook up?
Voters
17. You may not vote on this poll
  • I'll be attending and will join the Saturday cook up
    6 35.29%
  • I'll be attending and will join the Saturday cook up with another person - 2 meals needed
    6 35.29%
  • I'll be attending but won't need to join cook up Saturday night
    5 29.41%
Page 25 of 81 FirstFirst ... 2324252627 ... LastLast
Results 241 to 250 of 809
Thread: VIC meet up - Friday 16th November to Sunday 18th - Murrindindi-Scenic-Reserve
  1. #241
    Thomastown, Melbourne
    6 Post(s)
    12 days........... whats the go with the clutch Healy?? a little vague as to whats happened mate???
  2. #242
    Hardcore healy's Avatar
    south east melbourne victoria
    Well I can press the clutch and select any gear and it won't drive if that explains it any better damn thing is in pakenham still gotta get it home looks like a tow truck might be needed as I don't anyone with a vehicle that could tow it on a tandem it's all just fun and games at the moment
  3. #243
    Did you go through deep water???
    Check the little drain hole in your bellhousing. Is your bung in there? Take it out mate and leave it out.
    I had exact same problem and it was just water stuck in there.
  4. #244
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Not long now AB lol
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  5. #245
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    hope you get it sorted healy
  6. #246
    Nah no water unfortunately I might be able to get it done in time ill be absolutely f'd if I don't get done to meet you guys and I just purchased a long range tank how much should a heavy duty clutch cost?
  7. #247
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by healy View Post
    I think yours is a qg??? so I assume its single flywheel. you're only looking at about 600-700 bucks if you can put it in yourself. Don't forget the thrust bearing
    EDIT: just had a look , your is an rb30 and exedy hd cluch kit is around $450.. cheap as
    ________________________
    ______ 2017 D-Max _______
  8. #248
    Is that just for the clutch? Do I still need a thrust bearing?
  9. #249
    There will be a spigot bearing in the flywheel, the tip of the input shaft sits in that bearing. Strongly advised to change that while its all out. Some other nong, not mentioning any names forgot to do his... Anyhow, the thrust bearing should come in the kit, spigot bearing wont.
    Also I just got back from Murrindindi. They have done a good job of repairing the place after the fires. Its almost bitumen all the way until just after the final (veer right) turn off toward the camp grounds.
    AB I will have the friday off. I can go up earlier to somehow reserve places up there. Just really need numbers I suppose of just how many are going...
    Maxhead (4th November 2012)
  11. #250
    ACT
    WOW, check this out.... cluch , pressure plate and bearing. 345 with postage
    http://www.ebay.com.au/itm/EXEDY-H-D...ht_1554wt_1139
