Results 1 to 4 of 4
Thread: Fan belt tensioner...
    Onslow WA
    Yo team ZD30...
    I have a problem with my ZD30. Started to hear a bit of metallic rattle sound at low revs. Inspected today and saw that the fan belt tensioner has oil apparently leaking out of both ends and the fanbelt seems to vibrate more than usual (I can see 10mm deflection when it's running).
    So, wondering is it possible for that tensioner that looks like a little shockie to leak? I can get a replacement no problem, but was also wondering how do I remove the tension from the belt to allow me to slip off the fan belt so that I can safely remove the tensioner without it biting me?
    Thanks in advance
    Steve CAIRNS
    Hi Steve check out the search engine ,top right side of page Marked Advanced search.
    I was only reading something about this recently
  3. The Following User Says Thank You to threedogs For This Useful Post:
    steve4377 (24th October 2012)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Hi Steve,
    I guess it's possible for the damper to leak, normally the bushes flog out.
    Also have a close look at the alternator pulley, they run a clutch type pulley and are prone to failing.
    Here's how to remove the belt.
    Cheers Rodney
  5. The Following 3 Users Say Thank You to Yendor For This Useful Post:
    AJTich (18th March 2014), steve4377 (24th October 2012), Strugs (10th February 2016)
    Patrol Guru Morton's Avatar
    Sydney West
    make sure you fit an original Nissan belt, similiar price to aftermarket but wont give you grief, aftermarket can be a couple of mm bigger or smaller but play up, x 2 on the alternator although this is a different sound, you can hear the bearing failing in the alternator, when you hear this replace it straighaway, DO NOT wait, I prefer to fit an aftermarket alternator without the clutch but each to there own, if you dont replace it ASAP the bearing can seize & melt the shaft causing the small clutch assembly simply to fail, as it is under tension from the belt it can do some damage, it will eat your fan but can hit anything on the way out leaving you stranded in the middle of nowhere, you will want ur wife to be busty & wearing a bra to get you home so you can use her stripped down bra as a belt, or ladies stockings, I got home one night using my wifes gf fishnet stockings as a fan belt lol, wasnt on the GU though
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  7. The Following User Says Thank You to Morton For This Useful Post:
    steve4377 (26th October 2012)
