Results 11 to 20 of 22
Thread: Fuel filter change on td42
    Quote Originally Posted by oilpond View Post
    I changed my filters today but now the old diesel 4.2 drops the revs right down and seems to labour at idle?
    You did bleed it right up yeah?
  2. #12
    I have had to clean this out a few times on my GQ easy job. I would rather have it there than remove it due to the fact it still catches crap that if it wasnt there would go into the pump. Injector pumps are very sensitive bits of gear.
    Yeah i cracked mine on the weekend looking for this and it is not there and i think my Pump is knackered damn it! during my investigation i read about this so thought i'd post for all to see.
    My pump crapped itself on the Madigan trip but we limped home and i continue to limp now. When i went problem solving on the track i found a fair bit of crap in the fuel filter that was less than 10,000km old and i now think that some of that went into the pump because that filter is missing
  3. #13
    here is another post from another forum about it
    When our GQ started to run rough – we were left scratching our heads. The main fuel filter was fine. The fault was eventually traced to a tiny thimble sized fuel filter we never knew existed. When we approached our local Nissan service centre – they did not even know the filter existed and it took a lot of searching to locate the part. (Nissan Part Number 14371-R8025A approx cost $30)
    To Fit – Firstly remove the tiny thimble size filter. This is achieved by unscrewing the front banjo fitting on the injector pump. I then made a paper clip into a small fish hook and inserted it about 1 inch (25mm) into the injector pump and pulled it straight up – your filter should be on the hook. Replacing this small filter has given the old patrol a new life.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Chimo (22nd October 2015)
  5. #14
    Expert oilpond's Avatar
    Over here!
    Thanks mudrunner! i might have had some crap go thru into that today as the bottom of my filter,that is the bleeder part that screw off was pretty filthy...
  6. #15
    Over here!
    um no:/i pumped it a bunch and then started it and it ran and then mellowed out and i held at 1500 and it came good but(ive never done much with diesels sept check em before work:?) It should come good with a stretch you think? as i havent driven it yet just held on a couple a grand for a few minutes and then the revvs wanted to drop down again...
  7. #16
    Use the hand pump and prime it until it is hard! this could take 5 to 150 pumps Just keep doing it until its hard then take it for a drive. Hopefully you have not got an airlock in your line. Newby will correct me if im wrong but i think that should see you right.
  8. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    oilpond (22nd October 2012), snewin (23rd October 2012)
  9. #17
    Over here!
    Eeek an air lock doesnt sound good! Ipumped it about thirty times only and thought it would do the rest itself(dickhead) i will pump pump pump in the morning thanks very much mudrunner!
  10. #18
    Over here!
    Yes the problem was air,lots of air! and a big fat dumass<<<<<Thanks to those that replied!!!!
  11. The Following User Says Thank You to oilpond For This Useful Post:
  12. #19
    I find it bleeds up quicker if you take the line of the output side of the filter. Pump it til there is a good amount of diesel coming out and reconnect line. Once the line is back on generally it will only take 1 or 2 pumps for the pump to hard doing it this way.
  13. #20
    Over here!
    I loosened the bleeder screw on the pump and primed and primed and then the bleeder screw on the filter and pumped some more...Should have done it the other way maybe but am stoked as it runs hard now and blows zero smoke
