Results 1 to 10 of 17
Thread: Turbo whistle
    Townsville
    Turbo whistle
    I have a yr 2000 GU with a ZD30 DI which has developed a whistle from the turbo.More noticeable when cold and seems to only have a slight whistle when warmed up.Doesn't seem to affect power though.I wonder if a scan for fault code would show any problems ?
    Mark.
    Mines doing the same thing, not over concerned, You may like to disconnect
    the battery for an hour,
  3. The Following User Says Thank You to threedogs For This Useful Post:
    bigmarkc (18th October 2012)
    Townsville
    I should say that its a loud whistle which turn heads from pedestrians.
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    Leak from somewhere? Possibly intercooler?
    GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
    KEEP OUR TRACKS LITTER FREE!
  6. The Following User Says Thank You to BearGUST For This Useful Post:
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    The turbo should or shouldn't have the whistle as it were ... if it "develops" a whistle, I'd suggest it's the manifold leaking, or the bush in the turbo (if not a bearing type). Nothing dramatic, but would be running a spanner over some things - I developed a louder than normal whistle on mine (which I didn't mind actually!! lol), but it turned out to be the back two bolts of the manifold being loose ...
  8. The Following User Says Thank You to Bigrig For This Useful Post:
  9. #6
    22 Post(s)
    yep you may have developed a boost leak, check your pipes, intercooler (especially) and manifold
    96 GQ coil/Cab
    08 G6eT
  10. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  11. #7
    Quote Originally Posted by bigmarkc View Post
    Mark.
    My work car is the exact year as yours and exact problem. Ended up being the intercooler the first time and now its come back again.
    Havent had a chance yet but I'll check mine this weekend. Stops after warming up but more noticeable when cold too.
  12. #8
    Townsville
    Will check...Thanks
  13. #9
    Being that its more noticeable when cold says to me its an exhaust leak. As the engine warms up everything expands which will close up the gap making it less noticeable once warm. Im with everyone else have a good look for an exhaust or boost leak somewhere.
  14. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    bigmarkc (20th October 2012), threedogs (18th October 2012)
  15. #10
    brisbane
    yea id look at the exhaust manifold mine did the same thing and had to machine it, mind you this was before its 20k service and was done under warranty but check it out id put $ on that
  16. The Following User Says Thank You to megatexture For This Useful Post:
