Results 1 to 6 of 6
Thread: Windscreen wipers excessive movement
    Beginner steve squires's Avatar
    Jun 2011
    Lightbulb Windscreen wipers excessive movement
    HI All, wonder if anyone else has had this problem and how ,if, they fixed it.
    I have a 98 GU wagon and wiper blades and arms ( i think ) have excessive amount of play. For instance when using wipers on a dry day to clean windscreen when they stop there is still a 1/4 of travel left to go. when using in rain the wipers will travel below the screen onto the body work and on the up stroke they travel onto the body pillar. Now I understand it may be worn out and therefor loose but before getting drastic I thought I check if anyone else has any ideas.
    Thank you
    Steve.
    You may find that it has worn nylon bushing on the arms, not sure how you'd get to it though
  3. The Following User Says Thank You to threedogs For This Useful Post:
    steve squires (10th September 2012)
    Hardcore
    central coast nsw
    x2 on the bushes had this break on Mk patrol yrs back.
    $40 relay arm with bush, but 10 yrs later and much younger model so $$??
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
    Legendary Alitis007's Avatar
    15 Post(s)
    Quote Originally Posted by steve squires View Post
    Thank you
    Steve.
    My gu had that when i bought it. One of the pivots where the arms bolt down on to had worn the drivers side i think , so i replaced both pivots and the two connecting arms set me back around a couple of hundred i think. But they're easy to get to you un bolt the arms then there is maybe 6 plastic screw type clips that hold down the panel under wiper arms, remove the rubber and lift the panel off can't remember if you need to close the bonnet or not. Oh and the nissan dealer i use had to order one of the pivots from japan, took a week or two.
    Also never use your wipers dry, just asking for problems down the track
    15 Post(s)
    Thats right it scratches the glass and wears the wiper components and strains the wiper motor
