Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 54
Thread: Utes with camping pods - Pics only, please
    178 Post(s)
    G'day Bakes,
    My shed's worse. Wish I had the means of lifting off the pod like that. Looks like you got a very nice clean one, & with alloys too if I'm not wrong.
    Welcome to the select group of Podologists.
    Cuppa.
  2. #12
    Expert GU CAMPER's Avatar
    Sheffield Tasmania
    I did a modification on my pod today
    Since it is getting very hot lately. I decided to get some more airflow in the pod
    Thought the best way was to take the whole door off. Lol
    NEVER USE A SNATCH STRAP ON A TOW BALL AS DEATH MAY RESULT
    GU 2005 Cab Chassis Ex Telstra POD, Set up for Remote Touring and Play
  3. #13
    Advanced Bakes's Avatar
    Jul 2011
    Townsville, QLD
    Ouch...hope it didn't fall on top of you mate. Actually only had this conversation with Obeico the other week. Not a cheap fix really, but I've put little wire ropes joining the two to hopefully stop it axing my head..
    2006 4.2TDi GU Cab Chassis - Twin Locked with extra....stuff
  4. #14
    Sheffield Tasmania
    It just missed my head
    I was chatting to GUtsy ute up at the meetup during the week about the hinges, looks like I will be ringing Obieco tomorrow for a new hinge
  5. #15
    Jul 2011
    Townsville, QLD
    Just make sure your sitting down when you do. I see it as my duty as a fellow forumite to prepare you for possible injuries due to falling in shock..lol
  6. #16
    Jul 2011
    Townsville, QLD
    Well I'm not sure wether these are an Obeico product, but I've noticed that repairs done to Telstra hinges near me seem to be replaced with these:
    Seems to be a more permanent solution to the black plastic hinge and still waterproof
  7. The Following User Says Thank You to Bakes For This Useful Post:
    twindiff (15th October 2012)
  8. #17
    Here to give you Poddies,podmeisters,podtologolist an idea or two .
    If this idea is of any use feel free, you will require a washer bottle and a momentary 12v button.
    What you see is a water outlet, as I had 55ltr internal s/s water tank in other 4x4 {no names}
    black round thing is Tomcat off a bonnet saves water by just giving a quick squirt
    3rd is air outlet from 3 gallon tank next to chassis,
    Only need 2mtrs of hose to air up.
  10. #18
    Beginner twindiff's Avatar
    Jul 2012
    Hornsby Heights NSW
    Gidday boys,
    Now that hinge problem is a drama! Any info on replacement hinges is greatly appreciated. I didn't know that the hinge was rubber. On mine passenger side looks ok BUT drivers side showing split/perished.
    Cheers,
    Errol.
    The best view of the city is in the rear view mirror!
  11. #19
    Sheffield Tasmania
    Hi Errol
    I got my new hinges from Obieco in Tamworth NSW there email address is serge@obieco.com.au
    They believe the hinges only last for 5-7 years
  12. #20
    178 Post(s)
    Had bit of a play today - first time I've set up the tents together with the camper. Had to set up the rooftop tent to suss out what modifications & repairs I need to get done, & thought as the sun was shining I'd try out the Oztent too. Was very pleased with both. Both sourced second hand via ebay. The Shippshape rooftopper has done a bit of work, but is in pretty good nick, the Oztent is an old 'real' canvas model & has hardly been used, in fact it's as good as new ...... & I was really impressed with how quick & easy it was to put up.
    Before anyone tells me how slack I am at putting up tents ...... I know I know, I was only checking that all was in good working order ........ oh & doing a little dreaming a little too. :-)
    If you turn off your sound you'll avoid the unnecessary wind noise. Not the most professional video, taken with the iPad which is very difficult in bright sunlight 'cos you can't see the screen to see what you're filming. May take a while to load.
    I'll put a few stills on my build up thread too.
    Cuppa
