This is a fascinating topic, and there are quite a few threads on here - I use the search function rather than wait for people to send a new response. Make a cuppa and put the feet up is my advice if all the info available here :-) There are also some manuals etc attached.
I use threedogs plates on my Mav. They are very substantial. While they sit fairly low on my Mav, there are other components that set the front approach angle, and I need them that low to get the straps out without rubbing too much on the factory alloy bar.
There are a couple of messages I came away with:
-The person that has to be happy is the person with the vehicle doing the snatching. If they aren't happy with the set up on the snatched vehicle, they shouldn't snatch.
- Most don't seem to like the front hook that comes on the GQ/Mav. Nor the rear loop.
-Depending on the bog, spade work will make the snatch a lot easier on components.
-Snatch straps have become real powerhouses now - years ago, 2 tonnes, now you can get 15 tonners. Apparently for heavy 4wheelers in touring rig with a trailer. The recommendation for my Mav is currently 8 tonnes. Is that breaking strain or some other rating?
- a bridle can be used to share loads across both chassis rails. EvilTwin I think put up a cracker of a post on bridles and how to use them. The longer the bridle, the better, from memory, and don't use a shackle to connect the snatch strap to the bridle. Thread it through the loop.
- at the rear, never use a tow ball. Most are unhappy with 'that' loop on the rear step.
-many people are happy with the hayman reece style receiver - there is controversy about whether the 16mm pin is up to the job, or it is necessary to use a dedicated fitting that goes into the receiver. I personally am happy with the plain pin that Hayman Reece etc sell, but would probably not use the locking pin that I bought to stop the tongue from being stolen. The steel in that locking pin is a bit of an unknown quality.... While I am happy to use the pin, to ensure that the snatcher is happy, I also have a bar and shackle arrangement for those who like that system :-)
- people have been killed by failure of the welds in the short tongue used in receiver hitches, due to unknown corrosion of welds inside the hitch.
Cheers, and apologies that this went beyond your question, I think :-)
