Results 1 to 4 of 4
Thread: Maf Air Flow Sensor
    Advanced knakkers's Avatar
    Hampton Park
    Maf Air Flow Sensor
    G-day guys
    After a bit of info regarding Maf air flow sensor
    Is somebody able to please tell me where the Maf air flow sensor is situated on a GU 2002 ZD30 engine??
    Reason i ask is because, ive started to develope a little bit of a flat spot in acceleration around 2000RPM in 2nd, 3rd & 4th gear, just before the turbo kicks in while accelerating up hill.
    Ive been told that the sensor could be dirty & give it a bit of a clean, that could be the cause of the flat spot issue. But i dont know where it is situated.
    Or does anybody have any other ideas on what could be causing the slight flat spot???
    Any advice would be greatful thanks.
    I have ran a bottle of diesel injector cleaner threw the tank to see if that will fix. No luck.
    I have recently fitted a Redback hi-flow 2.5" exhaust system & a Tunit diesel performance chip, (which has made a massive difference in torque & power) but at the same time inhanced the noticable difference of the slight flat spot.
    Now Divorced I can do what i like when i like. How good is life now
    02 GU111 Patrol 3.0TD Man, Chipped, Redback 2.5" Exhaust, Safari Snorkel, OME 2'' Lift, ARB W/Bar, Tigerz11 12000Lb Winch & R/Rack, IPF Lights, Cooper S/T Maxx 33's, Dual battery system, Uniden UHF, ARB fridge/freezer on ARB Slider, & heaps more
    Just left of the aircleaner with 2 torq screws holding it in
    Want a pic not raining here for a change
  3. The Following User Says Thank You to threedogs For This Useful Post:
    knakkers (2nd October 2012)
    Hampton Park
    Thanks Threedogs. i thort that might be it. Where the wiring plugs in?? Problem is i dont have a torx bit to fit.
    Strangely, i used to work at Kincrome tools & i have every tool under the sun except that size torx bit "Bunnings here i come"
    brisbane
    get a mini flathead screwdriver that will fit in side on and give it a bit should come loose and just spray dont touch .
