Results 1 to 10 of 14
Thread: High output alternator for GU Y61 3.0lt
    Hi does any one know about the availability or options for a high output alternator for GU Y61 3.0lt?
    2011 GU 7, Factory Bull bar, Factory shorkel, 12000lb Avenger winch, IPF driving lights
    Expert Squalo's Avatar
    Sunshine Coast
    I've never heard of an off the shelf option. That's not to say it doesn't exist, but I am well into my third year of modifying my car and if it was available I'd have shortlisted it...
    1995 GQ TD42 NA
  3. The Following User Says Thank You to Squalo For This Useful Post:
    Michaelh (29th September 2012)
    Feb 2011
    Shed
    45 Post(s)
    Mud runner TD told me about a high output alt for a td42 maybe pm him and see if he can steer you down the right path
    Double Tap
  5. The Following User Says Thank You to growler2058 For This Useful Post:
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I have been told about a 135 amp Hitachi alternator that will fit the ZD30
    This is the part number I was given LR1130-702C.
    I haven't looked into getting one yet.
  7. The Following User Says Thank You to Yendor For This Useful Post:
  8. #5
    Aug 2010
    adelaide
    Quote Originally Posted by Michaelh View Post
    have a read of this it could be an alternative
    stephen
    OH LEATHER IS NICE
  9. The Following User Says Thank You to my third 256 For This Useful Post:
  10. #6
    What price we looking at here, $1000 plus. why do you need so much charging power, 100 amps suitable for most.
    don't the higher charge ones have a slower start up rate off idle??
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #7
    Thanks guys. I have been looking at one on eBay item number 261089564877. Not sure if it is exactly the same mounting size, it does have a 6 groove pulley not the required 7. The seller states that it is rated at 170amp. at the price I am tempted to buy one.
  13. #8
    Looks interesting. It seems to have been fitted to 2007 Nissan Atlas trucks and Interstars with ZD30 engines. Not sure if it is available any were in Australia. An useful site with alternator catalogues http://www.as-pl.com
  14. #9
    brisbane
    yea i looked at getting my alternator restrung and was quoted 380-480 to make it 130amp cant rember it was a long time go but when i looked into it they didnt have any bolt in off the shelf units avalible but like i said it was a long time ago. and i was told the same 3dogs that it wouldnt charge till a higher rpm
  15. #10
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by megatexture View Post
    When you change the alternator stator windings from a star to a delta you do get a higher output from the alternator at high engine RPM, the downside is at idle or low RPM the alternator output is lower.
    If you purchase a higher output alternator (that has a star connected stator) the low RPM output of the alternator should not be that much different to the standard one.
    All alternators have a different output with regards to RPM.
  16. The Following User Says Thank You to Yendor For This Useful Post:
    Michaelh (1st October 2012)
