Results 11 to 20 of 28
Thread: h.i.d 's make my stereo crackle!!!!
    Feb 2012
    I fitted some cheapy evilbay ones, could not turn the radio on for the noise. Pulled them out and put then into my old Holden 1tonner just the same, went back to halogen.
    My own fault for being a tight arse I think, now I have to pay twice over to fix it.
  2. #12
    Advanced Boofa's Avatar
    I have this same problem except with a LED light bar which I have only just installed, I contacted the supplier of the lightbar who belives that some of these lights give out a frequency similar to the radio device, he couldn't really give me a straight awnser but said try a resistor on the radio or some sort of insulation on the positive wire to the light. I dunno anybody else finding this fault or have any other ways to rectify it?
  3. #13
    This is prob a thread where yendor would be really helpful
    Tappin
  4. #14
    I'd be checking the routing of the wiring between the ballast and the bulb. Try to keep it away from any other wires at all. If that doesn't work, then look into the filter.
    Sent from my GT-I9100 using Tapatalk 2
    Teno's Troll...
    08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
  5. #15
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Frequency induced noise can be a real pain to stop......ET is probably the best man for this job.
    Does the LED light bar have the c-tick logo on it?
  6. #16
    Hardcore
    central coast nsw
    Bugger.
    Read your thread earlier tonight.
    Went out to pick up my son.
    and my hids are making noise in radio wth.
    had these hids for over 12 mths and never had a prob before.
    Touch wood reception was weak , soon as I changed to good signal, noise ceased, WT Heck.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  7. #17
    Expert mick.'s Avatar
    Newcastle (NSW)
    It has a lot to do with the cheaper HID kits that use $5 ballasts. Usually the ballasts that come with the Ingitor box internally mounted in the Ballast don't have this problem. The biggest drama these days is that everyone wants compact ballasts which means the ignitor (black box) is mounted in the cable not the ballast so there's more chance of interference. The higher quality ballasts all have the ignitor inside the ballast or in some OEM cases the bulbs.
    That's why you don't see those big black boxes on the factory Denso ballasts you see in Lexus or Toyota. The other place they fit them is on the end of the bulb eg D1S bulbs.
    I personally wont sell any ballasts that have the ignitor externally mounted in the 55 watt as these seem to be the worst. There can also be other things that cause it such as poor earthing. Each ballast needs to be earthed correctly and poor quality wiring is another.
    Cheers Mick.
  8. The Following User Says Thank You to mick. For This Useful Post:
    Robo (17th September 2012)
  9. #18
    Hardcore healy's Avatar
    south east melbourne victoria
    Glad I've never had this problem before good luck fixing it fellas
  10. #19
    This might sound stupid .but you may find it works.
    Check the EARTH on your antenna and let me know result.
    You may be surprised its from the secret book of fixes, lol
    thats if it works.
  11. #20
    22 Post(s)
    thats if it works.
    You are onto something there. At work (industrial electrician) Where we have devices that cannot have induced noise. we use a screened cable (exactly the same as the screen on an antenna cable) and teminate it at 1 end only to keep the noise out.
    96 GQ coil/Cab
    08 G6eT
