Results 21 to 30 of 44
Thread: GQ steering wheel
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by gf0012-aust View Post
    mate I have an N13 steering wheel on the maverick. straight bolt up. you need a puller, celtic cross wheel brace and some grunt.
    http://tinyurl.com/gf0012-aust-Gallery then go to the "bits and pieces" image folder
    slightly smaller diameter than original, but is same depth and actually you have better control and reach to the wands
    $20 at the wreckers.
    Just remember to leave the nut on at top of shaft until after the steering wheel releases, or face full of steering wheel will happen.
  2. The Following User Says Thank You to Finly Owner For This Useful Post:
    benno (13th January 2011)
  3. #22
    Nov 2010
    canberra
    Quote Originally Posted by Finly Owner View Post
    Controlled release... bearing pullers are your friend... once you get the first "crack" of release, its basically a controlled event...
    if you yank it about a like a mad cats whiskers then you deserve to get some involuntary cranio facial surgery from the steering wheel coming off.....
    90 GQ DX Shorty
    89 Maverick LWB
  4. The Following User Says Thank You to gf0012-aust For This Useful Post:
  5. #23
    anyone know where i can get the original black sports wheel that came out on some models of GQ?
  6. #24
    Quote Originally Posted by Macgyver View Post
    Go to a Wrecker and have a look for one in a Nissan Pulsar or Stanza from that era mate, they will bolt straight in and some are near identical.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  8. #25
    Bought an N14 from the wrecker in perfect nick... bolts straight on and horn works.
    N14's have slightly deeper dish than N13's but either are OK and both are slightly smaller than Patrol standard.
    Biggest advantage to using an N13 or 14 Pulsar (non airbag)... they have "Nissan" embossed in the wheel so no-one do rego inspections picks 'em as undersize or changed out... hehehehehe
  9. The Following User Says Thank You to the evil twin For This Useful Post:
  10. #26
    Exactly right. N14 steering wheel likes right at home in my Terrano. You'd be doing well to pick it's not the original wheel.
    Tony
  11. The Following User Says Thank You to YNOT For This Useful Post:
  12. #27
    Off to the wreckers I will go!!!! Thanks Guys..
  13. #28
    Jul 2010
    Waterford West Qld
    I watna set of level gauges like yours Tony
  14. #29
    Had to have another look at that pic and realise that it is not a GQ but rather the Terrano as described. I thought you must have grabbed some out of a Yota.
    I had some in the GQ for a few year but found it far more appropriate to look out the bloody windscreen, steer and drive rather than trying to figure out if the slope has hit 30 degrees yet
  15. #30
    The inclinometer altimeter pod thingy in Nugget was factory fitted by Nissan. I plan to remove the inclinometer and fit boost and pyro gauges in the pod.
    Tony
