Results 1 to 10 of 49
Thread: Spray Painting Tips and Tricks
Threaded View
    Why dont you want to use 2pac? For solid colours its far easier to apply with a good finish and doesnt require a clear coat. With acrylic its all the prep work the painting is maybe only 10% of the job. If you dont do the prep you will have to start all over again. Also high quality paints like ppg etc make life easier too.
    Im sure steve with all his expertise will be able to help you no worries at all. Make sure when spraying you keep the gun an even distance from the vehicle at all times to give a nice even coat.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    patch697 (13th September 2012)
