Been thinking of a thermo fan, asked the question here before and most were of the opinion
not really worth it. MUDSKI I'll PM where to get the scoop not far from you.
A fair bit of work has gone into these scoops, they are designed by a Turbo freak.
The internal vanes direct air to the front of the IC, where as an OE scoop all air goes to the rear of IC.
Meaning this IC will work at a lower speed possibly around the 60kph mark, where an OE
does nothing till 80KPH.
bullbars redirect the air, ever seen a moth or similar go into the IC ??????
This same person, turns your vacuum turbo into a pressure system there for eliminating
Dawes and needle valve, boost and EGT guage still required
