heres a link to Pirahna who sell them...
http://piranhaoffroad.com.au/index.p...n16q4vckal2f23
taslucas (8th September 2012)
Bunnings sell similar items in the gardening aisle - they are hose extensions for old dears to water hanging baskets - put a thinner end on it and it will work wonders.
Good Idea - The bunnings one will probably be a bucket load cheaper too!!
X 2 on the lanolin/lanatec I use it on every thing, even good for your tools, hi lift jack.
Can't recommomend it enough. Any thing you can find Lanolin is good for camping gear,
leaf springs, Axe heads, if you can name it you'll find lanolin will protect it.
WARNING:::: be carefull when using on battery terminals, allow it to dry. MAY CAUSE A FIRE
Spray on decking it stops termites even, best stuff ever
hey 3D does the lanolin stay sticky [its wool fat isn't it?] would beach sand stick to it?
3lt GU 111 Wagon 2 inch lift,3in Taipan exhaust, cross country intercooler,catch can,EGR blocked, dawes and needle valve,Pyro/boost gauge ARB lockers,steinbaurer chip, long range tank, s/s water tank, draws, warn winch, and other stuff.
good tips guys, cheers
