Results 41 to 46 of 46
Thread: Looking at swb with/for my son.
  1. #41
    Feb 2011
    Shed
    45 Post(s)
    Any ideas on a particular brand drop box being easyer to be passed so-long as no cutting required obliviously.
    And the young feller expects to pay for parts forgot to mention but thought that was a given.
    PM MudRunnerTD he uses drop boxes and will be able to steer you in the right direction mate
  2. The Following User Says Thank You to growler2058 For This Useful Post:
    Robo (28th August 2012)
  3. #42
    Hardcore
    central coast nsw
    Timing chain may need attention bit noisy.
    think tensioner is either loose/worn/faulty.
    FYI.
    A kit is available to do chains on TB42.
    Both chains.
    tensioner and each guide also.
    front seal.
    $240 overnight local bullseye store.
    No pulleys for this $$.
    They are available but I didn't price em.
    Genuine, Just under $190 for chains only, nothing else.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  4. #43
    Charleville QLD
    My shorty tends to drain the battery if left unattended for a week or so - I believe it turns on the brake lights intermittantly.
    Easily the best 4WD i've had (5 others)
    best turning circle out in the bush - curtesy of being a shorty
  5. The Following User Says Thank You to Les Penrose For This Useful Post:
    Robo (5th September 2012)
  6. #44
    id look at something simpler, mq or mk non turbo diesel swb....strong cheap and almost bombproof and still simple to fix and maintain.... just a thought?
  7. The Following User Says Thank You to iansmqshotyy For This Useful Post:
  8. #45
    Hardcore
    central coast nsw
    This is the family's 4th patrol.
    2 x MK, 2x GQ
    It's the young fellers first 4by and I can't begrudge his choice.
    He doesn't want diesel.
    Only try and a make the most of it, father son relationship.
    I hear you MK L28 dam simple but tb4.2 leaves it for dead power and economy wise and the chassie well, no comparison in 4 x coil sprung handling.
    He wants to tackle the Wattagons etc near by and Id rather he have something more capable anyhow.
    I think he made a fair choice, and I dont want to have to preform rescue if I can help it lol.
  9. #46
    Hardcore
    central coast nsw
    Quote Originally Posted by Les Penrose View Post
    The battery drain you will find isn't a common problem.
    Power has to be getting threw / bypassing brake switch for it to be draining bat if thats the problem.
    Huummmm--- Do you have elec brakes, possibly getting by here.
    an alarm, another potential drain.
    there is alot of causes.
    Huummm--- May be try 1 of those load fuse test devices to see if you can locate the drain.
    I personally haven't used 1 but I think they temporally replace the fuse and you can sight the load on that circute.
    That may help you pinpoint drain.
