Hey guys juz curious as to wether the swivel hubs need grease or oil? Mates mq uses grease but his missus 80 series is oil. Wots right for the GQ?
Soooooo..... You come here often??
grease for the swivel hub bearings, grease for the CVs. There is a recent thread about which kind of grease is best for each application.
RIP - valued member and true gentleman of this forum that will be missed by many!
"As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
Grease!!!!!
IF YA DONT GET STUCK YA AINT TRYIN HARD ENOUGH........OR YA TOOK THE CHICKEN TRACK![]()
Grease ... fullstop.
Not oil for our mighty Patrols mate.
I woulda thought a toymota would br the same. Oil in a troll anyway indicates a stuffed axle seal
I went looking the old fashioned way, which found this thread, but not the one I was looking for
http://www.nissanpatrol.com.au/forum...-4x4-full-lock
Ok cool, now how do I get the grease in there??
Breaks, I think it is time you made the search function your friend. Otherwise you will wait for someone else to either recreate the info in a new post. Or someone might decide to do the search for you.
Being impatient, and having had lots of success with getting the info in the past, I like to use the search function.
I used it to find the thread I was looking for about what grease https://www.google.com/url?q=http://...eZ-roteA-TEzNQ
For instructions on stripping the hubs back to the CVs, which includes the Swivel Hubs, there is a ripper, with pictures, in one of the mechanical sections of the forum, with pictures etc - just outstanding.
So, You could either go to the general mechanical section, and just plough through the posts there - that will take ages as there are lots of posts and too many distractions :-). It would be in Feb last year's posts, or thereabouts, from memory, or a bit earlier, because I used it in Feb.
Or, look at the red coloured strip across the page, towards the top of the page. There is an empty rectangle there. Click in it, and type whatever you think will find the info you want - try replace swivel hub - and see what you get. Hitting Enter or clicking on the magnifying glass kicks off the search. You can see 'advanced search' in the same bit of the page. You could use that instead, and if you know who started the thread, put their user name in to refine the search. In this case it could be Ynot, but I'm not sure.
Good luck with it, and if you need any more help with Searching, just ask.
Have fun
Breaks (28th August 2012), MudRunnerTD (26th August 2012)
This is the link ya want http://www.nissanpatrol.com.au/forum...hlight=replace
Breaks (28th August 2012), MudRunnerTD (26th August 2012), Silver (27th August 2012)
Only in the bottom one ... potentially. And only if the swivel bearing plug has been removed (plastic plug that seals the swivel bearing off from the trunnion housing) .. the axle seal being stuffed "should" only spew into the trunnion housing onto the CV if the swivel bearing plugs are still in place... if a mechanic has swapped your swivel hub bearings and replaced the bearing seats/cups, then I'll bet my left one they removed the plug to get the seat out and never put the plug back in ... dodgy ...
