Hi guys, so I get the patrol back from getting the new low ratio diffs in and drive probably 300kms until I was stopped at a petrol station and noticed a stream of coolant had run from under the car in the time it took me to fill the tank and pay. So I drove it home and parked it, the temp never rose above normal and it still had some coolant the next arvo when took it off and it looked fine, thinking maybe it was just the gasket that was leaking I re sealed it with some Loctite blue RTV gasket silicone... It never dried after 14 hours and leaked just the same, so I pulled it off again and used a better silicone gasket glue for radiators and such and left it for 24 hours again. it had dried nicely so I filled up the Rad with water to sets it and it leaked again.
So.... am I over torqueing the bolts, or is the water pump stuffed? I am only doing the bolts up with a short maybe 5" spanner and they come undone easier than who they were the first time I undone them.
This hole has a water stain around it, Is it leaking from there for some reason?
I filled it up with water to see in the morning if it has leaked out.
Let me know if you think I just need to get a new water pump or I am doing it wrong. Oh and I can't get the pulley and clutch off the pump... any clues? I have undone the 4 nuts and nothing happened, doesn't look like it will be coming off any time soon.
Thats from totally installed, removing ALT belts, dumping the coolant, removing the fan, all other bolts
