Results 1 to 3 of 3
Thread: what holds my gu indicator in???
    Expert Boagie's Avatar
    margaret river wa
    Question what holds my gu indicator in???
    Sorry guys about this stupid question,but does the indicator assembly in my gu 99 have 2 screws holding it in or do you simply take the top 1 off and prise the assembly out????
    You don't drive...you patrol!
    99 gu dx 4.2 diesel cab chassis - "THE GOLD DIGGER"
    In mine there are 2 screws one small one and one really long one which acts more like a pin than a screw. remove these 2 then a small amount of pressure and she should pop out.
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    Boagie (22nd July 2012)
    As above remove smaller screw on the plastic tab, using long nose plyers pull the other one up. there are 2 snap fit locating pins. Bit fiddly but come out ok. Just make sure they are fitted back in correctely so that long pin locates properly
    Boagie (24th July 2012)
