Results 1 to 10 of 14
Thread: UHF - Check my theory
Threaded View
  1. #13
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by MK TANK View Post
    1. What is displayed in the sceen - check the ICONs against the manual http://www.gme.net.au/public/pdf/man...x4500-3_im.pdf . You may have enabled quite or CTSS mode,
    2. have you jumped started the truck recently - did the set start playing up afterwoods. When you jump start you can creat a voltage spike - when you connect the cables that can kill electronic components
    One reason you should put fuses on both Positiv nd Negative wires on all UHF and CB sets.
    Tim
  2. The Following User Says Thank You to Finly Owner For This Useful Post:
    NewDan (20th July 2012)
