Hi all I have a gu wagon zd30 vnt turbo it is very sluggish all through rpm boost kicks in around 2500 rpm to 2 psi and then up to 5 psi at 3500 no vac leaks Dawes valve cleaned intake blocked egr all fitted catch can goin in soon exhausted all ideas even tried making the actuator arm shorter as someone has tampered with it but can't seem to get more boost next option I have is needle valve to take all power away from boost controller help I'm runnin out of ideas
