To Check a rig:-
1. Visual check of the antenna, cable wiring connectors mic - anything obious.
2. VSWR check - this will confirm that the cable and antenna is ok, and that the radio is trasmitting the correct power.
3. Still a problem, the unit is pulled and put on a bench and connect to a service monitor. Power, deivation receiver sensitiity et is checked.
The most common problem is always connecotrs, cable run and antennas
(Im a radio tech)
