Results 1 to 10 of 12
Thread: bull bar modifications
    Expert tassie wombat's Avatar
    orielton,tasmania
    can air bag compatible bull bars be structurally modified/strenthened without altering how the air bags are set off? want to fit a highmount to a factory steel winch bar,chassis mounts needs to be strengthened and centre section of bumper needs to be cut and moved out.cheers
    You can't interfere with airbag sensors, might not have depth to suit the hi mount plus you need to cut half your grill out, only seen it done on comp trucks, try sourcing a airbag compatible bar to suit the hi mount, like Millweld, or Cheesy, Aroc maybe. Sell old bar on fleabay' Millweld bar and matching sliders would be cool'
    Millweld aren't airbag compatible from memory
    Tappa tappa
    threedogs (12th July 2012)
    Oct 2011
    Morayfield. Queensland, Australia
    The law states, on an airbag vehicle you cannot modify the bull bar in anyway.
    David
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Check to see if this one is airbag compatible :http://www.gumtree.com.au/s-ad/gleno...bar/1004272485
    Its in tas
    Hello from Under Down Under!
    Quote Originally Posted by KRISTOFFA View Post
    Tappa tappa
    Just checked on this, and they definitely aren't airbag compliant.
    orielton,tasmania
    So can anyone tell me where the airbag sensor is on an 04 st wagon ? Because there is nothing on the bar !
    You can't disconnect sensors or alter the crash can, all the comp trucks with the mod you want to do had no reg. look for airbag compatible bar that will fit that winch, still think the Aroc MIGHT be suitable, through OP LOC I think?
  10. #9
    Any particular reason you are wanting to go highmount. As its been said you can not modify and ADR air bag approved bar as then its not original. I would be calling around to the bigger mobs like tjm or arb and see if they do a bar that is compatible and airbag approved. Nissan is a little strange as I own an 04 ST ute and i has no airbags and by my undetstanding these are on the wagons?
  11. #10
    Just looking at the readers rigs on home page. theres a GU from QLD running a high mount with a tube bar of so sort, not sure if it was ute or not but worth trolling through the pics to send him a PM
    think Knackers has one too
    Last edited by threedogs; 12th July 2012 at 01:52 PM. Reason: looked up readers rigs
