Results 1 to 10 of 21
Thread: Tigerz11 Winch
Threaded View
  1. #6
    Nov 2011
    Brisvegas Northside
    Installed mine yesterday,only took about 45 minutes it was pretty easy. Heaps of room inside the bullbar.
    I am yet to mount the controlbox though, its currently sitting inside the bullbar top recess....trying to workout what I want to do.
    I also will have to get a die-grinder out and modify where the rope exits the hawse, its currently running from the bottom of the winch and over the steel bar.
    Hopefully just grind the steel down on the bar, and maybe need an offset hawse....wont be hard.
    Pretty happy with the kit, had everything required including longer mounting bolts. I stripped it down and had a look inside,also rotated clutch lever 90 degrees.
    Its not hard to uninstall,so its not going to be hard to maintain regularly. Hopefully get to give it a work out soon.
    CHeers
    Dave
    99 GU 2.8 TD
    Brisvegas, QLD
  2. The Following User Says Thank You to robbo0001 For This Useful Post:
    Tonks (12th July 2012)
