Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: $730. Too much to replace a rear main seal????
    4 hrs Work maybe even at $100 an hour, no where near $750
  2. #12
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Just gave it another degrease and had a bit more of a look. It appears that the front seal is leaking a bit too. I thought it was the sump gasket that was leaking but i reckon its the front seal leaking and running around the lip of the sump.
    Ive lined a mate up to do the rear seal. Im guessing the front seal can be done at a later date as there is no doubling up on labour etc?? (sooner rather than later as its already weeping)
    Hello from Under Down Under!
  3. #13
    You can buy shims for these can't you? My mate did on his 302 powered 75s ute
  4. #14
    Aug 2011
    North West Tas
    56 Post(s)
    Just priced up seals. Genuine from nissan: Front $32, rear $77. Not bad for genuine.
  5. #15
    Expert Gas_Guzzler4800's Avatar
    Aug 2011
    Capalaba
    In our workshop and others in my area, removal of a 4x4 gearbox will usually vary between $450 and $650, add to that the cost of removing, cleaning and reinstalling the sump. Plus cost of the gaskets and seals. Sounds about right to be honest. Patrols are knowns to leak at the front seal, I have seen a few sump gaskets leaking but more commonly front and rear main seal.
  6. The Following User Says Thank You to Gas_Guzzler4800 For This Useful Post:
    taslucas (9th July 2012)
