Ok so I have heard of plenty of people fitting N14 and earlier steering wheels to their Patrol and I had heard that fitting a later model Pulsar wheel was possible but nobody had explained what might be involved in making one fit. For ages I have been looking for a mint condition stock standard Patrol wheel, I have seen a few but they always are selling for over $100 which is too much for a twenty year old steering wheel in my opinion. So I found this N15 wheel in the wrecker when scouring for some other parts and thought bugger it I'll give this a go. So here is what I started with.
Unscrew the small screw underneath and pull the horn fascia off, then 4 more screws will remove the rear cover and you end up with three bits.
This pic shows the rear cover and how I have removed the centre hub part, I did this with a vibrating renovator tool but a dremel should be able to do it aswell.
This is the tool I used although you could probably use a dremel or something just as well.
