Results 1 to 10 of 11
Thread: Uneven braking on trailer brakes
Threaded View
  1. #2
    Oct 2010
    Old Bar, NSW
    Took a while for the electric brakes to bed in on a new trailer we built.
    Have you recently replace some parts? Or has it sat for a while and things are a bit frozen inside the brakes.
    It could also be a coil, having voltage there doesn't mean it works. A DC clamp meter will show if current flows, or does it draw a spark when the local cable joint is seperated?
    Good Luck Macca
  2. The Following User Says Thank You to macca For This Useful Post:
    MATSTA (4th July 2012)
