Results 1 to 7 of 7
Thread: High Tensile Bolts
Threaded View
  1. #6
    Expert Biscuits's Avatar
    Driving the Beerbulance around the Tweed Coast
    Quote Originally Posted by Finly Owner View Post
    I was reading a thread and noticed high tensile bolts mentioned. With being involved in strong discussions involving raised voices at work, I thought I would make a thread about the blighters.
    Firstly, high tensile bolts can be identified by either marks or numbers:
    0 lines; Grade 1or2
    3 lines; Grade 5
    6 lines; Grade 8
    then you have 4.6, 8.8 and 12.9 rated
    Many people believe you should use HT for any pulling force. But Ht will snap not bend when stressed. I have been advised that HT is for taking strain along the shank from top and bottom, not from side.
    But for more info look at these links below I found while making this thread:
    http://www.qldcorvetteclub.com.au/te...talk/bolts.htm
    http://www.offroaders.com/tech/Bolt-Identification.htm
    hope this helps
    as an ex fastener rep (nuts & bolts salesman) your very close.
    no lines = Mild steel imperial (Metric equivalent is class 4.6)
    3 lines = grade 5 HT (Metric equivalent is HT8.8)
    5 lines (most manufacturers) = grade 8 HT (Metric equivalent is 10.9)
    6 lines = grade 8 ht some manufacturers/ grade 10 very few manufacturers (Metric equiv 12.9)
    Most socket head caps screws (allen key bolts) will be 12.9ht or a class 10steel.
    I will try and find some of the training manuals I had for the newbies, and post them up if your interested
  2. The Following User Says Thank You to Biscuits For This Useful Post:
    Finly Owner (26th June 2012)
