The front crankcase breather hs been rotated in this pic . It was pointed directly into the hose. It is pressed into an unthreaded hole in the block. I just kept turning it with a pipe wrench while pulling hard and it eventually worked free.
The other pic shows the top breather. The open end goes into the clean side of the air cleaner
I will take some pics of the final result later and post them. I am a bit embarrassed by the welsh plug as it should have been 25mm not 1” and it is a shocking install job.
Cranky
Reason: Ooops -- next time I will make the arrows stand out more
