Page 25 of 28 FirstFirst ... 2324252627 ... LastLast
Results 241 to 250 of 274
Thread: Michelle's MQ Resto
  1. #241
    Napier, NZ
    1st up...Don't you DARE quit!!!!
    2nd, heaps of guys here can help out which they will!!
    Seeing all the work you've done, and the advice all the gurus have given to you is what has given me the confidence to do my project myself.
    Whoever disagrees with the saying "Might is right" obviously doesn't own a MQ
  2. #242
    It probably needs a good to run you may have to reco your injectors if she has been sitting for an extended period. I would certainly be changing your filters (engine and fuel), a nice fresh tank of diesel and some new oil give her a nice little run around the yard and see how she goes.
  3. #243
    Feb 2011
    Shed
    45 Post(s)
    As above injectors
    Tapp tillya Crap
  4. The Following User Says Thank You to growler2058 For This Useful Post:
    Michelle (20th June 2012)
  5. #244
    Advanced 1nertia's Avatar
    Reckon you'll open a body repair shop after you're done with your current project? you have more skills that half the smashies I know!
    Keep up the good work, I wish I had half the guts to do less to my GQ.
  6. #245
    Jul 2010
    Waterford West Qld
    Michelle, love, don't dispair. It ain't all bad.
    Glow plugs don't give up the ghost reguarly. I doubt they need replacing. Is your GLOW PLUG TIMER working properley? Do you wait for it to click before winding over your motor?
    Do you use your throttle lock instead of the exccellerator pedal for cold starting, then wind it down to idle?
    Check both your air filters are clean and have not had a rat build a nest in there. This would choke the motor and cause excess Diesel Smoke.
    Your Blue Smoke is unburnt Deisel, either caused by overfuelling or crook injectors.
    Up here you can get exchange injector set for approx $400-$500. With instruction sheet how to fit yourself.
    So your Shorty is a long way from being a pile of crap yet!!!
    Tim
  7. #246
    Quote Originally Posted by Finly Owner View Post
    Tim
    Just to confirm- Blue smoke is oil, black smoke is over fueling and white smoke is unburnt diesel.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
    aussiemale (20th June 2012)
  9. #247
    Jul 2010
    Waterford West Qld
    I knew that, I'm just tired and not thinking straight. But din't know white smoke. So thanks for that. I also thought overfuelling was unburnt diesel, so need to understand the difference there as I haven't quite graspe that one yet.
    Tim
  10. #248
    Yeah white smoke is raw diesel when it has been atomised. Overfuelling doesnt allow the fuel to burn completely hence the black smoke. I have thrown a link up in general mech for it its a good read and is sure to help everyone.
  11. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    aussiemale (20th June 2012), Finly Owner (22nd June 2012), Michelle (20th June 2012)
  12. #249
    Expert Michelle's Avatar
    Sep 2011
    Horsham, Vic
    Thanks guys do ill check out the injectors, filters and oil already done, and ill drain that old deisel out and go from there, Tim I do let the glow plugs warm up and i use the peddle when i start her up, its all good just something ealse to add to the list lol
  13. #250
    Napier, NZ
    add to your list?? Damn, what's that like? I'm still in the novel stage..not expecting to get to the list stage for at least another 8mths LOL
