Results 1 to 10 of 36
Thread: Reverse light on GU
Threaded View
  1. #18
    Nov 2010
    Quote Originally Posted by Apollofish View Post
    Hi, a mate suggested I use LED's so as not to put to much drain on the electrical circuit. Anyone have any views/ideas on that?
    Also where can I source the globes and globe holders etc? I've had a look on ebay but may be searching in the wrong area.
    Appreciate any advice.
    Apollofish
    I was instructed not to use led as they were not bright enough.
    Yes it will put a small drain on the tail and brake lights and when towing a trailer you might blow a fuse BUT i was told by Nissan that one of the fuses either brake or tail, i cant remember now will blow when using a trailer anyway and that they replace it with a extra +5 or +10 amp fuse.
    2008 GU walkabout 3L auto wagon, 2" lift, Nissan winch bullbar, Ironman winch, Roo lite spotties, Scrub bars & side steps,Ferret rear light bracket with two Led work lights.My tip, Always carry a good well stocked in date firstaid kit when 4wding medical help is always to far away.
  2. The Following User Says Thank You to bushytas For This Useful Post:
    jack (19th June 2012)
