Results 11 to 20 of 21
Thread: The dreaded wheel wobble.
    NW Tas
    I've had my GU get better with first finger balancing the rims (ie a 6 stud fitment attached to balancer and wheel bolted onto that - not just a cone spun into the rim centre as is commonly done).
    And then finishing with an on-car balance on the front tyres - only problem there is once you rotate or swap tyres, unless you mark it its gone, and IMO still never quite the same afterwards if swappign from road to play tyres.
  2. The Following User Says Thank You to gu4500 For This Useful Post:
    Cuppa (8th March 2013)
  3. #12
    Advanced snowy's Avatar
    Adelaide
    my poo does the exact same thing mate, no wobble till 72kmh then bad wobble to about 85kmh. my mate works at a alignment workshop and says its extremely common on the gu. theres shims in the swivel hub somewhere that need attention. im going to look at it in the next week or so. he claims its a very easy task to perform. ill let ya know
  4. #13
    Sunshine, Victoria
    Quote Originally Posted by snowy View Post
    Would love to know how that goes because just in a few minutes on this forum, the wheel wobble at those speeds looks to be quite common and I've got it myself. Makes me feel better than it is a common problem in a way, but everybody seems to have a different solution. Keep us updated as I'm moving to Broome in 3 weeks from Melbourne so I'd like to have it fixed before then. Cheers.
  5. #14
    Nov 2012
    Quote Originally Posted by jman69 View Post
    Hey fellas, can anyone out there give me a list of probable causes for the front wheel wobble? Very minor untill about 75-85 kph. Also at that speed while turning through a bend it is almost un noticible. I drive a 1998 GU.
    I have a GQ 4.2 diesel and same for me. I fixed mine by my self.
    This is how and please try this method.
    I figured that there has to be an alignment problem even after a few alignments and balances with no improvement what so ever by the so called specialists!!
    If you have the front axle to far back in position from the nissan build stage, you can have problems, where some have it, and some don't. As the old saying goes, the Monday and friday cars are the worst finished.
    What I did was, take the the nuts holding the Radius Arms off at the rear of the arm directly under the front seats. ( don't take the radius arm off ) take the cover off behind the nuts and take one of them to a nut and washer dealer of some sort and purchase 4 to 6 washers the same size as the hole in the cover Place the cover on one radius arm
    and place 2 washers on and screw the nut on until it's just starting to tighten, do the other side the same.
    swap from one side to the other tightening the nuts evenly as you go. [ just take your time]
    What this does is, it pushes the front axle forward just that bit and at high speeds keeps it smooth. By the way, the axle will move because the universal joints will move accordingly to that forward movement.
    This will not change your wheel alignment, so don't be scared of that.
    Take your car for a run and if you feel it is a lot better, but not quite there, take the nuts off and put another washer on, or take one off and go for a run, it may only need one washer on each to fix it.
    Once you get that right, you will be able to fit tyres, get them balanced and have no troubles. I had my wheels balanced before I did this work.
    It might sound funny, but unless that front axle is set up right, that's what you get.
    Iv'e had on car balances, the lot and nothing fixed it, this has!!
    My GQ has had 2 sets of tyres fitted since I fixed mine and goes like a new one, a pleasure to drive.
    Big bazza
  6. The Following User Says Thank You to big bazza For This Useful Post:
    Lonicus (8th November 2012)
  7. #15
    Do one thing at a time so you can let others know your problem' Firsts I'd balance the wheels.
  8. #16
    Patrol God Stropp's Avatar
    36 Post(s)
    well just to let you know that my gu developed a wobble and after a bit of investigation i found the wheel bearings are loose so as its been like it for a while now i am installing new bearings, will report back when its done.
  9. #17
    Advanced andrewh's Avatar
    Yanchep
    Easy fix and all good! We had a similar problem for ages and tried various fixes. In the end it was a change of tyres that made the difference. Our Kuhmos had 80 000 on them and looked good for another 20K but they were the source of the wobble. Tucked that one away for another time
    2007 3.0L GU Patrol
  10. #18
    Mar 2013
    Gympie, Qld.
    Hi jman69 - I have a 1998 TD 2.8L manual and had the same problem recently. Took it in for a wheel balance and found out I needed a new tyre (had a bubble in one). Got 2 new front tyres (which were just about due) and problem solved.
    Regards
    Wayne
  11. #19
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    I recently had the Work below done by Pedders :-
    1. Control Arm Bushes
    2. Radius Rod Bushes
    3. Drag Link Replacement
    4. Sway Bar Bushes
    5. Steering Damper Replacement
    6. Brake Fluid Flush & Replacement
    7. Rear Sway Bar Bushes
    8. Sway Bar Ball Joint
    Wheel Alignment
    Before having this done I had a slight Wobble at approx 80 KPH but now have no Wobble whatsover
    Expensive way of fixing the Wobble but that was not the reason I had the above work done.
    BTW the old Girl drives like a new one
  12. #20
    Mar 2013
    Check if the rim is buckled, I had that probem on my GQ, even had the wheel balanced. you'd think the tyre place would have picked that up but they put a cover over the wheel as it balances so the buckle is not visable. Jack the car up and spin the wheel you'll see it straight up if theres a problem.
