Thanks ET, I was hoping you would see this post...haha
The previous owner is touring around Australia at the moment and they kept the cord unfortunately.
It will just be used to play the Wiggles for an hour before bedtime that's all....lol
A wiggles fan eh... which one is your fav colour?
No biggee not having the cord...
If you want to make one up from stuff lying around pretty much any ciggy plug lead will do and you just need to solder on the appropriate size socket on the other end (Jaycar, Dickies etc will all have 'em) if soldering is out then a bit of a search will find "screw terminal" plugs
If you need a quick off the shelf solution those retailers will all have el cheapo ciggy plug ins with about 6 to 10 interchangeable plugs on the other end, one of which should fit the Conia.
I think the Conia will be 2.1 mm jack plug but don't hold me to that.
