Results 11 to 20 of 31
Thread: Touring spares and recovery gear.
    Feb 2011
    Shed
    45 Post(s)
    This is my favourite....Maxtrax (this is Version 1) and a shovel, of course
    I've also heard of a couple of strips of carpet work too (can double up as a 'ground sheet' for the swag). Never tried that myself though, but would be doing a trial run in controlled conditions before I attempted it out there.
    Off subject a little bit.....I'm a firm believer in driving to the conditions. You shouldn't be driving your troll like you stole it, or doing a TV advert.
    PPPPP as been mentioned before. Plan your trip and allow extra time for anything unexpected.
    Ya missed a "P" rossco
    Tapp tillya Crap
  2. #12
    Sep 2011
    adelaide
    18 Post(s)
    PPPPPP as been mentioned before. Plan your trip and allow extra time for anything unexpected.
    G`day DX
    Have seen these jiggers used and would recommend that a long, strong rope be tied to them as they disappear into the depths due to wheel spin and then are hard retrieve but with a rope attached its allot easier.
  3. #13
    WA Wheatbelt
    23 Post(s)
    G`day DX
    Version 2 has the rope or something similar, and a bit of a design change. Thanks. Rossco
  4. #14
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    besides the 6 P's also take into account the KISS principle - Keep It Simple Stupid - the more exotic or unnecassary things you do to your rig or needless gear you take will nearly always end up in a mess
    www.swat4x4.com
  5. The Following User Says Thank You to oncedisturbed For This Useful Post:
    DX grunt (28th May 2012)
  6. #15
    Rural Goulburn
    Although I have not used much on my own car or caravan I have helped others and it gives me the confidence to travel to interesting, fun and remote places.
    Actually maybe I have, Just thinking about it, I once held an engine in place between two jacks and the mud guards after the mounts failed, I have replaced a couple of wheel bearings on the side of the road , welded up a spare battery bracket, welded the end on a Tie rod on my sons GQ,
    You can break someting and have an issue doing the Monkey Gum fire trail at Yalwal or the Oodnadatta or the Gibb River.
    The baby chainsaw is great I have been temporarily stopped by a tree at Lloydes siding near Dorrigo Some of the FT's near Goulburn but its best for FIREWOOD.
    Most of the stuff goes in a larger metal tool box and weighs about 25 KG.
    My tool list Tools ( and I have this list on the computer because I suffer badly from CRAFT) (Cant Remmember A Flamin Thing)
    Sockets
    Metric spanners
    Imperial spanners
    Pliers
    Screwdrivers
    Chisel/punch
    Baby chainsaw and bits
    Visegips
    Allen keys
    Ball pien hammer
    43mm hub nut socket
    Multgrips
    LPG torch
    Solder
    24 volt stick welder kit
    Tyre levers / pipe
    Tyre patch from the inside
    Tyre plug kit
    Battery drill / drills
    Angle grinder
    Small multimeter
    Air jack
    hydraulic jack
    Screw jack
    Blocks of wood
    ¾ axe with full handle
    Air compressor
    Head torch
    Jumper leads
    Leather gloves
    My supplies list
    Radiator hose s
    Silastic
    Tek screws
    Araldite
    Contact glue
    Electrical tape
    Gaffer tape
    Small bolt and washer selection
    Fuses
    A couple of sizes of tie wire
    About 5 metres of electrical wire
    6mm fuel line
    8mm fuel line
    Selection of hose clamps
    Epoxy metal putty
    2 metres of 3mm chain +3 mm locks
    Tub of grease
    5 litres of oil
    500 ml of brake fluid
    2 stroke fuel
    Chainsaw oil
    WD40
    spare ford whell bearing
    Spare holden wheel bearing
    Wheel and axle nuts
  7. The Following User Says Thank You to Crankshaft For This Useful Post:
    Flo-w (18th October 2012)
  8. #16
    177 Post(s)
    Re. Max Trax - I've seen a few folk recommend these things, but boy thet are pretty expensive for two pieces of moulded plastic. I'l probably eventually convince myself to get some, but I really can't see how their price can be justified. Is it really because nothing else is as light or does the job as well?
    Cuppa
  9. #17
    Expert Rip'n'Shred's Avatar
    Hunter Valley, NSW
    Great list crankshaft. Cheers, I might use that.
    GU IV 2006 4.2 TDi wagon
  10. #18
    NE Victoria
    That list is awesome crankshaft not much would stop you short of throwing a leg out of bed.
    Hey cuppa, a cheaper and somewhat effective substitute for max trax is a couple of hessian bags filled with small branches etc, the bags pack up nice and small. Super cheap also sell some rubber roll out type max traxy type things.
    91 Maverick, TD42 Naturally Athsmatic, GU airbox, Red Arc battery management, HID upgrade, UHF, 2 inch body , 2 inch Iron Man, Bighorn 33's , Homemade cargo barrier, Rear 1/4 cut, Homemade rear bar, Roofrack , soon to be installed front Lokka.
  11. #19
    Jul 2010
    Waterford West Qld
    Have done Simpson and read the aboveand watch Action 4WD. You will need extra fuel, long distance between fuel stops. Suggest enough drinking water to survive 5 days if stranded plus what you need per day I think it's recommended 10L/day. This can be topped up at stops that have water. You need to be self sufficent with cooking method by gas etc. Keep clothing to minimium but have both summer and winter clothes. Hot days cold nights. Because you are travelling through some aboriginal areas, you may not be allowed to have a petrol chainsaw, so I recomend just an axe to cut some fire wood. A good toolbox of mechanical tools. Exhaust jack would be lighter than hi-lift. Air compressor is a must. Shovel. Two torches.
    We took two spares wheels and needed none. Shocks were taken and used two sets of spares. Spare light bulbs of all types, fan belts, thermostat, gasket paper and sealant make a good choice of spares.
    Tim
  12. #20
    Expert HammerBuilder's Avatar
    Lismore, NSW
    Thanx guys this is been good reading as a few us down here are doing a postie bike run from cairns to the cape in sept so this will be a great start for us in our trols.
    Keep up the good ideas
    Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
