Results 1 to 6 of 6
Thread: Winch Troubles
Threaded View
  1. #4
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    if you put the clutch lever to "free wheel" ,can you turn the drum in the "in" direction by hand ?
    see if the motor will turn both ways (under power) with the clutch set to free wheel.
    you could also try swapping the power out cable on the motor for the in cable, this could help rule out a power supply issue ?
  2. The Following User Says Thank You to 04OFF For This Useful Post:
    c7cornell (26th May 2012)
