Page 21 of 1057 FirstFirst ... 1920212223 ... LastLast
Results 201 to 210 of 10566
  1. #201
    WA Wheatbelt
    23 Post(s)
    I drove my troll to w..... and home - a total of 2km. I was lazy today, being Sunday. lol
  2. #202
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    I made an el dodgy fridge slide...lol
    Used proper runners from a kitchen supply shop near work, screwed down some marine ply and found a pot plant pot holder that fitted the fridge perfectly.
    Total cost $20 and it works a treat!
    Nice and simple AB. It looks good and works, gives you more satisfaction than fitting a fancy store bought one.
  3. #203
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    Dude that wasnt much more than me(for the same reason)
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
  4. The Following User Says Thank You to Drew For This Useful Post:
    DX grunt (13th May 2012)
  5. #204
    Patrol God Stropp's Avatar
    38 Post(s)
    recieved my pyro and boost gauges from Kholo and dummied them up, just need to hook them up.
  6. #205
    WA Wheatbelt
    23 Post(s)
    Trying to charge my batteries with the solar panels, but the sun won't come out and play.
  7. #206
    Feb 2011
    Shed
    45 Post(s)
    Drove her to work and whispered sweet nuthins to her hahahahahahaha
  8. #207
    Apr 2011
    Forestdale Brisbane
    Quote Originally Posted by growlers71gq View Post
    Did She start getting hot?LOL
  9. #208
    Feb 2011
    Shed
    45 Post(s)
    nah shes a tuff biatch and told me to p155 off hahahahahaha
  10. The Following User Says Thank You to growler2058 For This Useful Post:
    GUtsy ute (18th May 2012)
  11. #209
    Lets see.
    • I pulled the intercooler and hoses off, the heat shield and dump pipe from the turbo off. There was a stud missing from the turbo to dump pipe, so I replaced all of them, gave the dump pipe a well needed diet. Made up some new IC mounts as the original ones were nearly non existant and bugger if I was going to pay $28 each from Nissan. Ended up costing my $8 from Clark Rubber for all four mounts
    • Welded in a bung for the pyro.
    • fitted blue LEDS in the dash
    • Received my all in one boost and egt gauge from the states today. Yippee! Looks wicked!
    • Bought a Autometer cup for the gauge from Rare Spares
    • saw a birds nest of wires under the dash from the spotty switched in the dash. So I decided to remove it all and re-do it. Just aswell as the wires under the hood to the fuses they used were all melted, even though it was all still working.
    • and also ran around like a blue arsed fly trying to find a bulkhead fitting for the vacuum sensor, found one in the end.
    Still haven't finished any of it, everything is spread all over the garage. I'm still waiting of the dawes from 3Bar to turn up so it can be fitted with the catch can, needle valve and EGR plate. This will take a while to complete. Just aswell I have my other car to use, if it doesn't sell that is...Then I'm stuffed.
  12. #210
    Nelson Lakes, New Zealand
    Went to an accident in the middle of my village (high speed multiple rolls and end over ends) once we had him sorted out and packaged away me and my Safari got to recover his Surf which was in the local pubs garden on its roof facing the wrong way with the back end wrapped around there new large sign. Had to pull the back sideways off the sign then winch it forward about 1.5m and then winch it back onto its wheels. I then had to strip all the guards of my winch as I managed to engage my winch (pretty sure my fire jacket got caught on PTO lever) when I was getting out and over swpooled the winch into a large tangled mess that jammed up between the which drum and the fairlead.
