Results 11 to 20 of 29
Thread: Which tyres and rims for the GU?
    Jul 2010
    Waterford West Qld
    Kat-trol I like it!
    Tim
  2. #12
    Nov 2010
    Getting a life...
    38 Post(s)
    Me too ! My new rego plates maybe. KATROL. Makes sense to me.
  3. #13
    Expert Cadbury's Avatar
    Nov 2010
    Waterford QLD
    What size tyres will fit a standard 1999 GU? I will be doing a lift soon, should I wait until then before getting tyres
  4. #14
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by Cadbury View Post
    Yep definitely ... irrespective of 2" lift, 3" lift or whatever best off waiting so you can eye it up and suss out what they look like, whether they'll scrub the guards etc.
    All the best with it.
  5. #15
    Hey Kat, if your still making the decision and are looking for rims too then Offset will be important.
    A standard Nissan Offset is +10. I would recommend chasing a rim with at least a Negative offset for your 33s
    If you run 15" tyres then you will be looking for 33s
    If your running 16" tyres then you are looking for 285/75R16.
    I would recommend a Neg 6 to Neg 22 for the best fit.
    Changing the offset to a Neg offset will spread the wheels pout from the centre of the car and they will sit closer to the outside of the wheel arch guard and limit the likelihood of scraping the inner guards.
    Also, not sure what motor your running in your GU? If you have an engine other than the mighty 4.8l Petrol then you can if you want go to a 15" rim as they will fit around the brakes no problem. I would stick with the 16s though if your going to do allot of mud.
    Hope that helps.
  6. #16
    Nov 2010
    Getting a life...
    38 Post(s)
    Thanks Mudrunner, I have no idea about offsets but I have a mate that seems to know all these things ( in theory anyway) so I'll get him to explain it to me. I have 4.5 petrol but have been told not to run 15s.
  7. #17
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    Hey Kat. Always good fun lookin for the right tyres.
    Just to give you a bit of an idea with a 2" lift and 265/75-16s on a GU
    There a BFG A/T ko, found them to be brilliant on and off road, and they're not hard core but can handle the rough stuff with ease.
    Only thing I regret, Didnt get 285s
    Cheers Pete
  8. The Following User Says Thank You to wildgu6 For This Useful Post:
    katwoman (22nd December 2010)
  9. #18
    Advanced Patrica's Avatar
    Sydney
    If you use your fourbie mostly on the road then a set of all terrain is the way to go, I've got a set of Mickey Thompson atz 285/70/R17 but I think their a mud terrain pattern as the lugs are so big. Like the rest have said the rear barn Door should be fine to carry the spare, I had to get a spacer from arb to fit it on as I didn't like the tight fit, but if your still worried about, spare wheel carrier is the way to go, you can also carry an extra spare or Jerry cans, I'm going to go down that route soon.
  10. The Following User Says Thank You to Patrica For This Useful Post:
    katwoman (12th January 2011)
  11. #19
    Nov 2010
    Blacktown
    I had impression that 33'' should not rub with 2" lift or is it only on GQs?
  12. #20
    Oct 2010
    Quote Originally Posted by wogboy View Post
    33's would probably rub with only 2" on a GQ - GU's have bigger wheel arches and accommodate bigger tyres more easily. I have a 4" lift and 33" tyres and not a bit of scrubbing anywhere (GQ).
  13. The Following User Says Thank You to Bigrig For This Useful Post:
    wogboy (13th February 2011)
