Results 11 to 20 of 25
Thread: What do you think about Low Range Reduction Gears
    Oct 2010
    Old Bar, NSW
    Thanks guys, sort of leaning toward the 85's, they seem to step the gearbox 1 gear or very close to.
    So what I do now I just have to be 1 gear higher.
    Is that what you have found BigRig?
    2 guys in our club have them, so I hope to have a yarn with them when we do our next trip.
    I know 1 of them doesnt like the lack of momentum, but I dont know if he has run out of gears in low range. He must be fair hooting!!!!
    Still researching...
  2. #12
    Oct 2010
    Old Bar, NSW
    G`day Macca.
    Don't be concerned about the CSR I did it in 08 towing a camper trailer using stock gears
    Main thing on the CSR is tire pressures 18 to 24 PSI no higher. I ran 18 on the car and the trailer with no problems not 1 flat.
    Run these pressures from start to finish and take your time and you will not have trouble
    We crossed the Simpson in our Lux using low 2 & 3 mainly (and 16psi) so I'm guessing we would be in 3 & 4 with these reduction gears.
    I am a fan of lowering tyre pressures and dont understand those who dont. Some think they are "tough???" saying I got through with out dropping a psi. If they look behind them they are more than likely damaging the track.
    On that Simpson trip we got stuck once and that was trying to cross a ridge in a gear higher than we had been using, only did it to see what would happen. Climbed Big Red with 10psi not a worry in the world. That was a great trip.
  3. #13
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Hmmm ... I'd say 85% is more like two gears at least mate. Will try to dig out the video I did, but I let the truck 'run away' in 4 low first gear on a hill at Landcruiser park prior to getting the gears and it maxed out at around 15 Klms per hour without brakes. Did the same hill post getting the 85's put in and it maxed out at about 3-4klms per hour .... that much of a difference ...
    I'm sorta thinking you might want to look into the 43's if you need to 'tour' as such in low range - my box (3 speed with overdrive) would be lucky to do 25klms in overdrive whilst in low range, and even then, the gears are whining pretty loudly (as they do) ...
  4. The Following 2 Users Say Thank You to Bigrig For This Useful Post:
    macca (12th May 2012), twisty (12th May 2012)
  5. #14
    Oct 2010
    Old Bar, NSW
    Be good to see the vid mate
    That chart I attached has the 85% closer to 1 step in gearing than the 43% or have I made a blue?
    2nd and 3rd are fairly close but they do get a bit further away in 4th and 5th.
    Real world driving is the best result anyway.
    I dont want to spend the coin and find I am revving hard in first all the time, prefer to be in 2nd and have another option available.
    Maybe the 4.2's can pull well enough in 2nd with a final drive of 28.86:1, if they do then the 43% is the winner
  6. #15
    Oct 2010
    I'll see if I can fin it boss as it was mid last year ... a manual 5 speed will be different, Dhuck has reduction in his with a 5 speed box, so he might be able to shed light on the topic. I know he tackles most hard hills (steep and hard) in third low from memory as it is really that low ... I don't reckon he'd be able cruise at all in low ...
  7. #16
    Could any of you guys who have reduction gears give me a rough idea of how much coin i would be looking at to get a set in my truck?
    Like the rest of you i am wanting slower crawling speeds on my 35inch tyres
  8. #17
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    http://www.marks4wd.com/products/gea...w-tc-gears.htm
    A handy tool to see what speeds in what gear to help work it out
    http://www.apexgarage.com/tech/gear_ratios.shtml
    Such is the rule of honour.
  9. The Following User Says Thank You to macca86 For This Useful Post:
    macca (14th May 2012)
  10. #18
    Hi Macca Have a conversion around where they use 2 transfer cases gives the best ove both worlds but you need a shortend t shaft and two high low gear shifts Ross
  11. #19
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by macca86 View Post
    Great link, thay has really helped, thanks from the other Macca LOL
  12. #20
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by Ross42 View Post
    Read about this mod on another forum, a bit to complicated and big for my needs.
    Read something about a "lefty"? the shafts are swapped side to side?
    The bloke that did it must of paid some as the installers came fro the States and did the mod at his home..... What The ????
