Results 1 to 7 of 7
Thread: broken exhaust mount on GQ / feedback on extractors
    Post broken exhaust mount on GQ / feedback on extractors
    Hi, this is my first post since joining up - hopefully I'm in the right place and not repeating anyone:
    I've just checked the diff/ gearbox oil levels etc under the truck and noticed that the exhaust bracket that runs from the gearbox mount area is broken .
    The bracket was sitting on top of the bash plate and was not connected to the exhaust - I believe it was not connected back up to the exhaust when I had the clutch changed about 3 years ago ! . - It may have just failed through fatigue and vibration - but it's a fairly heavy duty bracket .
    Anyone seen this before or has a spare one knocking around ?
    Also , I've a set of headers/extractors in the shed that i never fitted - As i look to be up for some exhaust work may be I'll fit them - any feedback on performance/economy ? motor is 4.2 TD non turbo , 320,000 kms
    Cheers everyone
    I can comment on the extractors for a TB42. I noticed a very small increase in power, probably not worth the time it would take to fit them. However, noticed a big increase in economy, definitely worth doing. I am now getting an extra ~60kms per tank of LPG.
  3. The Following User Says Thank You to Winnie For This Useful Post:
    malcolm (7th May 2012)
    Thanks kristoffa, interesting - a significant improvement in economy, I'll see if anyone posts a comment on diesels .Cheers
    Expert bordertech's Avatar
    Bordertown
    They always break whether on deisels or petrols, from normal engine and transmission vibrations because it's mounted solid to the pipe without any insulation from vibrations.
    I put a flexible strap join onto the bracket on mine years ago. Haven't had an issue since.
    I love terra firma - the less firma the more terra
  6. The Following User Says Thank You to bordertech For This Useful Post:
    malcolm (9th May 2012)
    Thanks for that , I'll do the same when I fix it, have a good day .
    Beginner Stusgq's Avatar
    Toowoomba
    Hey Malcolm, mate I have a set of headers on my td42, along with a 2.5 mandrel exhaust. It has made a slight differance in power, more noticebly in fuel economy. the best thing about it is the sound though, compaired to how it was stock it sounds great.
    hmm superflex & dobisons....
  9. The Following User Says Thank You to Stusgq For This Useful Post:
    malcolm (11th May 2012)
  10. #7
    Thanks Stu' - worth doing for the economy alone . Also it looks like you can get a 2.5 exhaust cheaper than the standard item - about $500 on ebay compared to $800 locally for standard item . Cheers and have a good evening,
