Page 17 of 1057 FirstFirst ... 1516171819 ... LastLast
Results 161 to 170 of 10564
  1. #161
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Quote Originally Posted by ripper View Post
    Drove it for 100 odd K's and wondered why it vibrates between 1800 and 2000 revs. Sometimes worse than others.
    Hi Ripper,
    There are so many things that cause vibrations, you usally have to do it by process of eliminationif there is nothing glaringly obvious.
    Some things I have found to check are, Diff and gearbox yokes tightened to the correct torque, uni joints,
    slidingspline on tailshaft, g'box and engine mounts, out of round or out of balance wheels, missfire in engine at higher revs, uni joints not properly aligned if siding spline has been taken apart. Not sure if this
    relates to a TB42, but I've seen the rubber in the harmonic balancer go soft on a car and cause the
    outerpart to wobble and cause a vibration at certain revs.
    Also check your viscous fan hub and water pump for any wobble or freeplay.
    I see you are looking for a wheel brace, I bought this one the other day from Bearing Service in
    Brisbane.
    It is a Toledo brand tool.
    Cost me $35.
    As you can see it folds up and can be adjusted in lots of ways.
    Also has the half inch square to fit any size socket.
    Much easier to store than my old fixed cross one.
  2. The Following 3 Users Say Thank You to GUtsy ute For This Useful Post:
    Dirtydog16 (24th September 2016), HammerBuilder (16th May 2012), ripper (6th May 2012)
  3. #162
    Advanced waz65's Avatar
    Wynnum West , QLD
    I installed my new GPS/Entertainment system into the GU , here's the linky from my members section
    http://www.nissanpatrol.com.au/forum...php?9717-My-GU
    Also gave my daughters Prado and oil and coolant change ( because that's what dads do )
    2000 GU Patrol TD4.2T with heaps of stuff
    2007 Bayside Campers Offroad CT with more stuff
  4. #163
    Expert ripper's Avatar
    Leeton NSW
    Quote Originally Posted by GUtsy ute View Post
    Hi Ripper,
    Some things I have found to check are ..............
    Thanks for that list. I've already checked some of those things, but you've given me some more to look at.
    Brisbane.
    Cost me $35.
    And thanks for that too. I'm hoping to find an original one to go with the factory jack, but the one you bought may be just the thing for our caravan. It has really long studs (for mag wheels maybe?) and needs a deep socket to undo the wheel nuts. I was planning to carry a cracker bar and speed brace, but what you got may work out even better.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  5. #164
    Apr 2011
    Forestdale Brisbane
    [QUOTE=ripper;223612]Thanks for that list. I've already checked some of those things, but you've given me some more to look at.
    Let us know how you get on, I'll try to remember some other things that i've heard of that have caused vibrations
    if you have no luck tracking it down.
    To keep this thread on track, I installed a voltmeter to monitor my second battery today.
  6. The Following User Says Thank You to GUtsy ute For This Useful Post:
  7. #165
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by growlers71gq View Post
    Bummer i did that a fortnight ago took me 45minutes to break in!!
    what do you mean 45 mins..........no other nissan gq drivers in Adelaide you know..... or have you changed your original locks......
    Still 45mins!!!!!! 2 mins on a bad day to break in 2 a GQ
    .........not that I know *L*
  8. #166
    Feb 2011
    Shed
    45 Post(s)
    Had another q there and a bluebird no go and near impossible to get packing tape in
    Tappin N Crappin
  9. #167
    Hardcore healy's Avatar
    south east melbourne victoria
    just orderd new 2" lift kit today have it in a week and going to put in my diff breather kit later today and change power steering hose
  10. #168
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Yesterday I helped my brother fit the swivel hub kit and wheel bearings. Finished in a rush as I had to drive 2 hours back home and pickup my girlfriend on the way. Shouldn't have rushed because we forgot ti drain the last of the old duff oil and put the new stuff in! Lol now my new diff oil is a 2 hour drive away and I only have a tiny bit in the diff, which means no 4wd for me for a while! Damn it!
    Tap, crackle, pop
    Hello from Under Down Under!
  11. #169
    How's the serenity boots's Avatar
    Sep 2011
    Replaced my headlight globes today and fitted permanant sun shades in the rear side windows of the wagon , home made from an old windscreen shade cover cut to size and a bit of velcro to hold them in place .
  12. #170
    Advanced BEP120's Avatar
    Central Coast NSW
    Half installed a 50 ltr water tank behind the rear seats today and installed the pump between the tank and rear draws.
    Hoping to wire the pump up tomorrow.
    2003 GU ST-L, ZD30TD, 2 inch lift, 2.5m side awning, cargo rack, snorkel, 285/75/16 M/T tires, cargo draws, cargo barrier, UHF, DVD/CD player, on board air compressor, duel batteries, B/Bar, spot lights, 50ltr water tank, Pillar pod with egt & boost gauges, catch can, egr block, dawes and needle valves, 3" exhaust.
