Results 1 to 10 of 40
Thread: Air Jack vs Lift Jack. Or other alternatives?
Threaded View
  1. #15
    Changing a CV in the bush with the Exhaust Jack.
    Would never go any other way. Note the wheel went under the car for safety and we ran the winch cable out to the side as we were on a side slope in this pic. Do that with a High lift or Bottle jack and feel safe? Good luck.
    Imagine the same photo in a Rutting Mud hole or Sand???? Murphy's law will alway put you in the worst spot when you need to fix it mate
    Exhaust Jack 100% of the time, it is part of my Standard Recovery Equipment.
    to do this with a Hi Lift i would have to lift the car from the front bar and allow for full suspension articulation to lift the wheel off the ground! That is a Long Way Up! Note the Exhaust jack is straight under the diff and the diff is nearly flat. all good and nice and safe.
    **Note in the top pic that the rear suspension is not even articulating!! the car is nearly in a flat stance as it would sit in your driveway!!
  2. The Following 7 Users Say Thank You to MudRunnerTD For This Useful Post:
    Ade (4th May 2012), AndyExy (18th May 2012), Bluecrab (20th August 2013), growler2058 (4th May 2012), NissanGQ4.2 (4th May 2012), taslucas (4th May 2012), twisty (5th May 2012)
