Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Patrol Recovery point ?
    Hervey Bay
    Hi, just getting my first patrol shortly and presumed that the bolted on loop on the middle of the rear bumper is a suitable recovery point for towing and snatch recovery as i've read you should never use a tow ball. Am i correct about this ?
    No mate that is not a rated recovery point so cannot be trusted. In my opinion the best way to go is to put a recovery hitch into your Hayman Reece hitch receiver like this
    http://www.ebay.com.au/itm/Recovery-...ht_2239wt_1139
    Another way to go is to remove the tow hitch and poke the strap through the hole and then replace the pin.
    But you are definitely correct about not using the tow ball as a recovery point, that is the number 1 no-no!
  3. The Following User Says Thank You to Winnie For This Useful Post:
    BigAL.H (28th April 2012)
    Feb 2011
    Shed
    45 Post(s)
    Check out this thread Al, but dont use that loop for a snatch whatever ya do mate http://www.nissanpatrol.com.au/forum...e-Fundamentals
  5. The Following User Says Thank You to growler2058 For This Useful Post:
    Expert Benno7's Avatar
    Nov 2010
    The front factory hook can not be trusted either
    Fit these to the front
    and one of these to the rear
  7. The Following 2 Users Say Thank You to Benno7 For This Useful Post:
    BigAL.H (28th April 2012), rusty_nail (29th April 2012)
  8. #5
    Feb 2011
    Brisvegas
    Interesting question BigAl.H.
    There are a few threads on here that contain a lot of valuable information, and peoples' opinions.
    You need a set up that both recoverer and recoveree are happy with, as well as being safe.
    For instance, I have fitted the front plates pictured above, despite being personally comfortable with the factory hook at the front of my GQ. No point stressing a potential recoverer who does not thinkg the same as me. Or stressing myself because no one will hook up :-)
    I also bought one of those fittings that go into the tow bar receiver, however I have since learned that the general (but not universal) consensus is that the factory tow bar pin is just as good.
    Opinions on this might differ, too, but I think that if it is a snatch recovery, the snatch strap should be the weakest link. Better to have a strap fail than have a strap pull a bit of metalwork off a chassis and launch it. Slow and steady and adequate preparation should keep the stresses and strains within sensible levels.
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  9. The Following 2 Users Say Thank You to Silver For This Useful Post:
    BigAL.H (24th September 2012), Finly Owner (30th April 2012)
  10. #6
    Expert dan&tamspatrol's Avatar
    brisbane
    if that loop at the back of the car is not rated for recovery what is it there for
  11. The Following User Says Thank You to dan&tamspatrol For This Useful Post:
  12. #7
    It is suitable for towing or as a tie down point.
    Tappa tappa
  13. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    BigAL.H (24th September 2012), dan&tamspatrol (28th April 2012)
  14. #8
    brisbane
    ok cheers mate
  15. The Following User Says Thank You to dan&tamspatrol For This Useful Post:
  16. #9
    Nov 2010
    I have seen one of the factory hooks fail (lucky no one was injured) and the dent it put in the steel tray of the ute recovering the Gq was unbelievable.
    The problem with the factory hook is it's welded to a plate and where it is welded it cracks then snap's.
    It maybe right for a few recovery's but are you willing to risk your life or someone else's life?
  17. The Following 2 Users Say Thank You to Benno7 For This Useful Post:
    BigAL.H (24th September 2012), growler2058 (28th April 2012)
  18. #10
    Good on you AL for asking though mate. Never know if you didn't ask and now you know and might have saved some damage or a life mate!
  19. The Following User Says Thank You to AB For This Useful Post:
