Results 1 to 10 of 11
Thread: Ls1 conversion for gq patrol
    Hi im chasing info on doing a ls1 conversion on my gq nissan patrol using castlemaine rod shop bellhousing. need to know what clutch, pressure plate and flywheel to use and where do i get them from? can i use a gq slave cylinder, clutch fork and throwout bearing? also whats the best way to go for computer and wiring?
    my motor came out of an 02 calais auto.
    please any info would be greatly appreciated
    reply....
    Should have grabbed the auto and just put an adaptor on for the transfer. Im surprised that they cant point you in the right direction from which you have purchased the bellhousing. Marks adaptors may also be able to help you out if you give them a call. Thats about all i can add hopefully someone will be along shortly to add.
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    mad_gq (20th April 2012)
    why... do you know how much it is to use the auto??
    Im not sure costwise mate sorry. I would have thought a similar sort of cost. It just removes the drama of trying to source different clutch parts and both boxes are strong and can handle good power. I think they still use a gm clutch but dont quote me on that. sorry i cant help you out more
    Jul 2010
    Waterford West Qld
    MAD GQ just a warning for your interest. You should rmove yourphone number from the post mate. Ask people to PMyou and exchange phone nubers there. You never can be sure who is scanning the internet for phone numbers to use in marketing etc.
    Tim
  7. The Following User Says Thank You to Finly Owner For This Useful Post:
    mad_gq (25th April 2012)
    eddietrx
    Guest
    You can buy a standalone wiring loom from ebay for about $600 for the ls1
    Feb 2012
    Quote Originally Posted by mad_gq View Post
    reply....
    As nissannewby said go auto. I wish i had would be heaps beta in the bush.
    I used marks bellhousing, clutch, pressure plate and flywheel. I also used their slave cylinder (only cause they said i needed one) however it is the same as the factory one i already had. As for throw out bearing it came with marks kit. The wiring loom i sent up to killla kustoms in QLD and he modded the engine loom for me.
  10. #8
    Kinglake Victoria
    Marks 4X4 have been great to me
    Cheers Andrew
  11. #9
    ANd don't get ripped off with a pcm reprogramme.
    http://www.ebay.com.au/itm/COMMODORE...item337523b221
    For $80 you get the same thing
  12. #10
    i brought my stand alone harness for 620 delivered to my door with them supplying the harness. usually you have to surply the ls1 harness and they chop it for you, i got mine through road runner offroad. they did a really good job too looks mint as.
  13. The Following User Says Thank You to blakee For This Useful Post:
    mad_gq (30th April 2012)
