Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Longer bump stops=more travel im confussed??
    Plus my folks are at Landsborough
    Right next door to the humble glasshouse playground
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    growler2058 (15th April 2012)
  3. #12
    Expert bordertech's Avatar
    Bordertown
    Quote Originally Posted by growlers71gq View Post
    Ive got the sketch pad out now. Sooo the extended stop will act like a pivot to help push the other side down??? Giving me more travel down on the other side (said out loud to meself very slowly)
    Eggzackery. But the main reason for doing it is to stop longer travel shocks from bottoming out before full shock compression thus preventing damage to them. The added bonus is that it will act like a pivot and help push the opposite tyre down on the ground (only limited by your shocks extended length) with more pressure giving better traction.
    I had to reduce the bump stop gap in the front of my GQ by 70mm so the front shocks didnt bottom out. The gap before was about 200mm, now about 125mm.
    I love terra firma - the less firma the more terra
  4. The Following User Says Thank You to bordertech For This Useful Post:
    growler2058 (17th April 2012)
  5. #13
    Sep 2011
    What are peoples thoughts on extending the front shock tower instead of increasing the bump stop length when fitting longer shocks to the front end? Would need a bodylift I would imagine.
  6. #14
    Bordertown
    Thats another way of doing it. You get the same travel, just less droop from the body, more uptravel.
