Ok, so I've just finished working on my patrol again........ This is what happened earlier..
The trol was going well no sign of problems. 4.5 dual fuel. I went to start the trol it made a grinding bang sound... wtf?? ... It did the same thing after a few times. Quite loud. After a few more goes it cranked over then went bang and stopped cranking.... Seemed like compression lock up..... At this stage I was rather concerned as I never ever had or heard this before.
I walked away and pondered for a while on the problem and how to get it going. After 10 or so min I thought Id give it one more go before i crack it..... Cranked it and it started....it was running like crap.
I thought I'd check the timing. The dizzy wasn't loose but the timing changed from my original setting. I always set the timing to about 7.5 deg before tdc and it was on about 13 or 14 btdc. I don't get it. How does the timing change by itself. I have an ecutalk all set to normal but surely this can't be the cause.
So if the timing was out this much the engine was locking up and not firing. It seem to kick backwards. Does this sound right???
How can the timing change itself from original setting on the harmonic balancer??? How do I stop this from happening again as I'm rather concerned.... .???
