Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 62
Thread: WTF is this!?!?
  1. #31
    Feb 2011
    Shed
    45 Post(s)
    no and not tellen
    I know i know........................pintara hahahahhahahahahahhha
  2. #32
    Hardcore
    central coast nsw
    Quote Originally Posted by growlers71gq View Post
    Na ,not that good.
  3. #33
    Cheers under the black cover is 2 connectors which look as though it joins the front and rear looms, its just the fuse thats got me buggered 2 different coloured wires??????????
    Yep its the junction plug for the front and rear looms
  4. #34
    Hey Growler, sorry mate just read your original post again. looking at the pic with the fuse holder and the pic you posted later with the cover off it appears that that wire does not go through the floor.
    I reckon its a lazy mans way of getting a fuse into a circuit. I think you will find they ran the Twin core and used both sides as Positive for the fuse run alone. As Yendor said Definitely Aftermarket.
    Before you go putting a fuse in that just trace it back to where it goes mate, You will find that one will probably go to the battery an wherever the sheath finishes the other side will split off and go to whatever it was going to power up. Maybe a floater in the engine bay!!! Should be really simple to trace though mate.
    growler2058 (16th April 2012)
  6. #35
    Hardcore
    central coast nsw
    rethought it could be Nissan's original idea for cat converter temp sensor this is where my gtr connects up
  7. #36
    Nah it just cant be factory! the rest of the wiring in that pic is the factory Loom! if that was from the factory it would be wrapped in the loom with the rest. Definitely junk. In the second pic that was posted by Growler you can see the loose wire running along the sill above the loom! No Way its factory.
  8. #37
    Hardcore
    central coast nsw
    My bad put my glasses on, had a better look at pics.
    inline fuse holder, bit strange
    looks like at least 20amp wire.
    maybe owner was short and wanted fuse where they could reach.
  9. #38
    Feb 2011
    Shed
    45 Post(s)
    Its strange as one cables red and the other black?? Oh well maybe a case of let sleeping dogs lay! Till i get the time to chase it anyways
  10. #39
    Hardcore
    central coast nsw
    I recon he mtd a compressor there
  11. #40
    Feb 2011
    Shed
    45 Post(s)
    Im the 3rd owner the second owner did nothin to it and the first was a mining company so it may have been something for them
