yeah it does. So the locker can essentially float on the axles in the centre? Front diffs were usually all the same apart from ratios obviously some of the leaf rears were larger. As long as the centre you get is the same ratio and out of the front it should be as simple as fitting the locker to it and re installing to your vehicle
