Results 31 to 38 of 38
Thread: Will 35's fit with a 2' lift?
  1. #31
    Penrith
    I just had a better look at my rear tires and they have been damaged on the outside of the tread (the outside of the flat that contacts the ground) and looked at the inside of the 1/4 pannel and noticed a small section of plastic (maybe 10cm long has been ripped of and there is definitely paint scrubbed of from directly above the outer edge of the guard. Is this what you were talking about MudRunnerTD? Is this the section you recommend i bend up? If so how do i go about it, just bash away or is there softly softly approach required, my GU is pretty much undamaged so i don't want to f@*k up my panels. This has taken chunks out of both rear treads so i really want it sorted. Thanks heaps as usual. (not by hand anyway?) There is no evidence of any scrubbing up front only in the rear.
    Ben
  2. #32
    Hmmmm? Have you got a pic you can post up Ben?
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Ben81C (31st March 2012)
  4. #33
    Penrith
    All sorted with my rear inner guards, actually it was the inside of the 1/4 panel, with the help of a mate i took the plastic guards of and just folded the sharp edge up out of the way, a small amount of paint chipped of so we hit it with underbody tar, let it set and replaced the plastic trim. Thanks for the advice i hadnt noticed this was what was damaging my tires until you mentioned possible damage to tires. That should sort it out under flex and when i get the lift she will be right for sure.
  5. #34
    Tassie
    I gave the GU a really good clean today and found a heap of rubbing top of rear guards, inside. I have no lift now with 33's and its rubbed back to shinny bare metal both sides rear, so if im doing same tracks with 2" lift i recon 35's will be too much, in my head it doesn't add up that they wouldn't scrub. I think i will stick to 33's and lift.
    I agree with this i have a gu with a 4" lift and 33"s and they scrub in the upper inner corner of the guards slight change in offset will see them just clear i dont see how you could get 35" with a 2" lift to clear and keep good flex.
  6. #35
    Wodonga
    Thanks to all of above, Patrol 2.8 how did the 2.8 go with the 35s fitted?
  7. #36
    Wodonga
    Quote Originally Posted by brucemacca View Post
    Just read rest of thread, don't worry I do not want more than 2" lift, so it is 33s max.
    Bruce
  8. #37
    Jul 2020
    Offset?
    Quote Originally Posted by patrol2.8 View Post
    heres mine with 2inch lift and 35s i had no problems running these tyres on my gu
    Hey mate what offset are u running so ur flush in stock guards
  9. #38
    Quote Originally Posted by Impulse View Post
    I think he's long gone mate, that post it from 8 years ago
  10. The Following User Says Thank You to rusty_nail For This Useful Post:
    PeeBee (27th July 2020)
